Datasheet Microchip MCP6042T-I/SN — Даташит
Производитель | Microchip |
Серия | MCP604 |
Модель | MCP6042T-I/SN |
The MCP604 quad operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230uA.
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Оperational amplifier (op amp) has a gain bandwidth product of 14 kHz with a low typical operating current of 600 nA and an offset voltage that is less than 3 mV
Купить MCP6042T-I/SN на РадиоЛоцман.Цены — от 29 до 2 129 ₽ 25 предложений от 16 поставщиков General Purpose Amplifier 2 Circuit Rail-to-Rail 8-SOIC | |||
MCP6042T-I/SN (SOIC-8-TR) | 29 ₽ | ||
MCP6042T-I/SN Microchip | 43 ₽ | ||
MCP6042T-I/SN Microchip | 88 ₽ | ||
MCP6042T-I/SN Microchip | по запросу |
The MCP604 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP604 operates with a single supply voltage that can be as low as 2.7V, while drawing less than 325 of quiescent current per amplifier. The MCP604 is available in standard 14-lead PDIP, SOIC and TSSOP packages. This amplifier is ideal for industrial process control, low-power battery-operated devices, portable equipment, data acquisition equipment, test equipment and low-end audio applications.
Корпус | SOIC |
Количество каналов | 4 |
Aol | 110 дБ |
Automotive Recommended | Yes |
CMRR Min | 75 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 2800 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 29 nV/rt(Hz) |
Iq Max | 325 µA |
Iq Typical | 230 µA |
Isc | 22 мА |
Lead Count | 8 |
Operating Voltage Range | 2.7 - 6.0 В |
PM | 50 deg |
PSRR Min | 80 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | Out |
Скорость нарастания | 2.3 V/µS |
Unity Gain Stable | Yes |
Vos Max | 2000 µV |
ΔVos/ΔTa | 2.5 µV/°C |
- MCP604-E/P MCP604-E/SL MCP604-E/ST MCP604-E/STVAO MCP604-I/P MCP604-I/SL MCP604-I/ST MCP6041-E/MS MCP6041-E/P MCP6041-E/SN MCP6041-E/SNVAO MCP6041-I/MS MCP6041-I/P MCP6041-I/SN MCP6041T-E/MS MCP6041T-E/OT MCP6041T-E/OTVAO MCP6041T-E/SN MCP6041T-I/MS MCP6041T-I/OT MCP6041T-I/OTG MCP6041T-I/SN MCP6042-E/MS MCP6042-E/MSVAO MCP6042-E/P MCP6042-E/SN MCP6042-E/SNVAO MCP6042-I/MS MCP6042-I/P MCP6042-I/SN MCP6042T-E/MS MCP6042T-E/MSVAO MCP6042T-E/SN MCP6042T-E/SNVAO MCP6042T-I/MS MCP6042T-I/SN MCP6043-E/MS MCP6043-E/P MCP6043-E/SN MCP6043-I/MS MCP6043-I/P MCP6043-I/SN MCP6043T-E/CH MCP6043T-E/MS MCP6043T-E/SN MCP6043T-I/CH MCP6043T-I/MS MCP6043T-I/SN MCP6044-E/P MCP6044-E/SL MCP6044-E/ST MCP6044-I/P MCP6044-I/SL MCP6044-I/ST MCP6044T-E/SL MCP6044T-E/ST MCP6044T-E/STVAO MCP6044T-I/SL MCP6044T-I/ST MCP604T-E/SL MCP604T-E/ST MCP604T-E/STVAO MCP604T-I/SL MCP604T-I/ST
- Amplifiers and Linear > Operational Amplifiers > General Purpose
MCP6042TI/SN, MCP6042T I/SN
