Datasheet Microchip MCP6044 — Даташит
Производитель | Microchip |
Серия | MCP6044 |
The MCP6044 quad operational amplifier (op amp) has a gain bandwidth product of 14 kHz with a low typical operating current of 600 nA and an offset voltage that is less than 3 mV.
Datasheet MCP6041, MCP6042, MCP6043, MCP6044
PDF, 1.2 Мб, Язык: анг., Файл опубликован: 4 мар 2013, Страниц: 40
Оperational amplifier (op amp) has a gain bandwidth product of 14 kHz with a low typical operating current of 600 nA and an offset voltage that is less than 3 mV
Купить MCP6044 на РадиоЛоцман.Цены — от 20 до 358 ₽ 50 предложений от 30 поставщиков Операционный усилитель, 14 кГц 4-х канальный полный вход-выход 6В автомобильного применения 14-SOIC N туба | |||
MCP6044-I/ST Microchip | 20 ₽ | ||
MCP6044-I/ST Microchip | от 47 ₽ | ||
MCP6044-I/ST Microchip | 74 ₽ | ||
MCP6044-I/SL Microchip | 157 ₽ |
The MCP6044 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP6044 operates with a single supply voltage that can be as low as 1.4V, while drawing less than 1.0 of quiescent current per amplifier. The MCP6044 is available in standard 14-lead PDIP, SOIC and TSSOP packages. This amplifier is ideal for industrial process control, low-power battery-operated devices, portable equipment and wearable products.
- Amplifiers and Linear > Operational Amplifiers > General Purpose
