Datasheet Microchip MCP6271R — Даташит
Производитель | Microchip |
Серия | MCP6271R |
The Microchip Technology MCP6271/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current.
Microchip’s MCP62x5 devices are extended industrial-temperature range (-40°C to +125°C), Rail-to-Rail input/output (I/O), single-ended operational amplifiers
MCP6271R-E/P Microchip | по запросу | ||
MCP6271R-E/SN Microchip | по запросу | ||
MCP6271R-E/SH Microchip | по запросу | ||
MCP6271R-E/OT Microchip | по запросу |
This family has a 2 MHz Gain Bandwidth Product (GBWP) and a 65° Phase Margin. This family also operates from a single supply voltage as low as 2.0V, while drawing 170 µA (typical) quiescent current. The MCP6271/1R/2/3/4/5 supports rail-to-rail input and output swing, with a common mode input voltage range of VDD + 300mV to VSS – 300mV. This family of op amps is designed with Microchip’s advanced CMOS process. The MCP6275 has a Chip Select input (CS) for dual op amps in an 8-pin package and is manufactured by cascading two op amps (the output of op amp A connected to the non-inverting input of op amp B). The CS input puts the device in low power mode.
MCP6271RT-E/OT | |
MCP6271RT-E/OT | |
N | 1 |
Корпус | SOT-23 |
Parameters / Models | MCP6271RT-E/OT |
Aol, дБ | 110 |
Automotive Recommended | Yes |
CMRR Min, дБ | 65 |
Количество каналов | 1 |
Description | Linear Op Amps |
EMI Protection | No |
GBWP, kHz | 2000 |
Ib, pA | 1 |
Input Voltage Noise Density, nV/rt(Hz) | 20 |
Iq Max, µA | 240 |
Iq Typical, µA | 170 |
Isc, мА | 25 |
Lead Count | 5 |
Operating Voltage Range, В | 2.0 - 6.0 |
PM, deg | 65 |
PSRR Min, дБ | 70 |
Package Width | - |
Rail-To-Rail | In/Out |
Скорость нарастания, V/µS | 0.9 |
Unity Gain Stable | Yes |
Vos Max, µV | 3000 |
ΔVos/ΔTa, µV/°C | 1.7 |
MCP6271 MCP6272 MCP6273 MCP6274 MCP6275
- Amplifiers and Linear > Operational Amplifiers > General Purpose
