Datasheet Microchip MCP6474-E/SL — Даташит
Производитель | Microchip |
Серия | MCP6474 |
Модель | MCP6474-E/SL |
The Microchip’s MCP6471/2/4 family of operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation.
The Microchip’s MCP6471 family of operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation
Купить MCP6474-E/SL на РадиоЛоцман.Цены — от 19 до 281 ₽ 22 предложений от 13 поставщиков MICROCHIP MCP6474-E/SL Operational Amplifier, Quad, 4 Amplifier, 2MHz, 1.1V/µs, 2V to 5.5V, SOIC, 14Pins | |||
AS358AMTR-G1 Diodes | от 19 ₽ | ||
MCP6474-E/SL Microchip | 49 ₽ | ||
MCP6474-E/SL Microchip | от 136 ₽ | ||
MCP6474-E/SL Microchip | от 281 ₽ |
This family is unity gain stable and has a gain bandwidth product of 2 MHz (typical). These devices operate with a single-supply voltage as low as 2.0V, while only drawing 100 µA/amplifier (typical) of quiescent current. These features make the family of op amps well suited for photodiode amplifier, pH electrode amplifier, low leakage amplifier, and battery powered signal conditioning applications, etc. All devices are designed using an advanced CMOS process and fully specified in extended temperature range from -40°C to +125°C.
Корпус | SOIC |
Количество каналов | 4 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 88 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 2000 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 27 nV/rt(Hz) |
Iq Max | 200 µA |
Iq Typical | 100 µA |
Isc | 32 мА |
Lead Count | 14 |
Operating Voltage Range | 2.0 - 5.5 В |
PM | 65 deg |
PSRR Min | 92 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | In/Out |
Скорость нарастания | 1.1 V/µS |
Unity Gain Stable | Yes |
Vos Max | 1500 µV |
ΔVos/ΔTa | 2.5 µV/°C |
- MCP6474-E/SL MCP6474-E/ST MCP6474T-E/SL MCP6474T-E/ST MCP6474T-E/STVAO
- Amplifiers and Linear > Operational Amplifiers > General Purpose
MCP6474E/SL, MCP6474 E/SL
