Datasheet Microchip MCP6032-E/P — Даташит
СерияMCP6032
МодельMCP6032-E/P
The MCP6032 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV.
Datasheet MCP6031, MCP6032, MCP6035, MCP6034
PDF, 652 Кб, Язык: анг., Файл опубликован: 10 фев 2010, Страниц: 34
The MCP6031 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV
Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604
PDF, 600 Кб, Язык: анг., Файл опубликован: 17 дек 2007, Страниц: 34
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
MCP6032-E/P
Acme Chip
MCP6032-E/P
The MCP6032 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail input and output swing. The MCP6032 operates with a single supply voltage that can be as low as 1.8V, while drawing less than 1 uA of quiescent current. The MCP6032 is available in standard 8-lead SOIC and MSOP packages. AEC-Q100 Grade 1 qualification is available for this device.
КорпусPDIP
Количество каналов2
Aol115 дБ
Automotive RecommendedYes
CMRR Min70 дБ
DescriptionLinear Op Amps
EMI ProtectionNo
GBWP10 kHz
Ib1 pA
Input Voltage Noise Density165 nV/rt(Hz)
Iq Max1.35 µA
Iq Typical0.9 µA
Isc23 мА
Lead Count8
Operating Voltage Range1.8 - 5.5 В
PM65 deg
PSRR Min70 дБ
Package Width.300in
Rail-To-RailIn/Out
Скорость нарастания0.004 V/µS
Unity Gain StableYes
Vos Max150 µV
ΔVos/ΔTa3 µV/°C
MCP6031 MCP6033 MCP6034
  • Amplifiers and Linear > Operational Amplifiers > Precision
MCP6032E/P, MCP6032 E/P
На английском языке: Datasheet Microchip MCP6032-E/P
