Datasheet Microchip MCP6032T-E/SN — Даташит
Производитель | Microchip |
Серия | MCP6032 |
Модель | MCP6032T-E/SN |
The MCP6032 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV.
Datasheet MCP6031, MCP6032, MCP6035, MCP6034
PDF, 652 Кб, Язык: анг., Файл опубликован: 10 фев 2010, Страниц: 34
The MCP6031 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV
Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604
PDF, 600 Кб, Язык: анг., Файл опубликован: 17 дек 2007, Страниц: 34
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Купить MCP6032T-E/SN на РадиоЛоцман.Цены — от 52 до 447 ₽ 35 предложений от 18 поставщиков General Purpose Amplifier 2 Circuit Rail-to-Rail 8-SOIC | |||
MCP6032T-E/SN Microchip | 52 ₽ | ||
MCP6032T-E/SN Microchip | 73 ₽ | ||
MCP6032T-E/SN Microchip | 78 ₽ | ||
MCP6032T-E/SN Microchip | 296 ₽ |
The MCP6032 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail input and output swing. The MCP6032 operates with a single supply voltage that can be as low as 1.8V, while drawing less than 1 uA of quiescent current. The MCP6032 is available in standard 8-lead SOIC and MSOP packages. AEC-Q100 Grade 1 qualification is available for this device.
Корпус | SOIC |
Количество каналов | 2 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 70 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 10 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 165 nV/rt(Hz) |
Iq Max | 1.35 µA |
Iq Typical | 0.9 µA |
Isc | 23 мА |
Lead Count | 8 |
Operating Voltage Range | 1.8 - 5.5 В |
PM | 65 deg |
PSRR Min | 70 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | In/Out |
Скорость нарастания | 0.004 V/µS |
Unity Gain Stable | Yes |
Vos Max | 150 µV |
ΔVos/ΔTa | 3 µV/°C |
Серия: MCP6032 (8)
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6032TE/SN, MCP6032T E/SN
