Datasheet Microchip MCP6033T-E/MC — Даташит
Производитель | Microchip |
Серия | MCP6033 |
Модель | MCP6033T-E/MC |
The MCP6033 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV.
The MCP6031 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Купить MCP6033T-E/MC на РадиоЛоцман.Цены — от 40 до 62 ₽ 10 предложений от 10 поставщиков General Purpose Amplifier 1 Circuit Rail-to-Rail 8-DFN (2x3) | |||
MCP6033T-E/MC Microchip | 40 ₽ | ||
MCP6033T-E/MC Microchip | 58 ₽ | ||
MCP6033T-E/MC Microchip | по запросу | ||
The MCP6033 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail input and output swing. The MCP6033 offers a single amplifier with a Chip Select pin for additional power savings. The MCP6033 operates with a single supply voltage that can be as low as 1.8V, while drawing less than 1 uA of quiescent current. The MCP6033 is available in standard 8-lead SOIC and MSOP packages. AEC-Q100 Grade 1 qualification is available for this device
Корпус | DFN |
Количество каналов | 1 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 70 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 10 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 165 nV/rt(Hz) |
Iq Max | 1.35 µA |
Iq Typical | 0.9 µA |
Isc | 23 мА |
Lead Count | 8 |
Operating Voltage Range | 1.8 - 5.5 В |
PM | 65 deg |
PSRR Min | 70 дБ |
Package Width | 2x3x0.9mm |
Rail-To-Rail | In/Out |
Скорость нарастания | 0.004 V/µS |
Unity Gain Stable | Yes |
Vos Max | 150 µV |
ΔVos/ΔTa | 3 µV/°C |
- MCP6033-E/MC MCP6033-E/MS MCP6033-E/SN MCP6033T-E/MC MCP6033T-E/MS MCP6033T-E/SN
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6033TE/MC, MCP6033T E/MC
