Datasheet Microchip MCP6021T-E/OTVAO — Даташит
Производитель | Microchip |
Серия | MCP6021 |
Модель | MCP6021T-E/OTVAO |
The MCP6021 operational amplifier (op amp) has a gain bandwidth product of 10 MHz with a low typical operating current of 1.0 mA and an offset voltage that is less than 0.5 mV.
Datasheet MCP6021, MCP601R, MCP602, MCP603, MCP604
PDF, 1.5 Мб, Язык: анг., Файл опубликован: 9 янв 2017, Страниц: 54
Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604
PDF, 600 Кб, Язык: анг., Файл опубликован: 17 дек 2007, Страниц: 34
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Купить MCP6021T-E/OTVAO на РадиоЛоцман.Цены — от 102 до 6 795 ₽ 7 предложений от 4 поставщиков IC OPAMP GP 10MHZ RRO SOT23-5 | |||
MCP6021T-E/OTVAO Microchip | от 102 ₽ | ||
MCP6021T-E/OTVAO Microchip | 6 697 ₽ | ||
MCP6021T-E/OTVAO Microchip | 6 795 ₽ | ||
MCP6021T-E/OTVAO Microchip | по запросу |
The MCP6021 provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP6021 operates with a single supply voltage that can be as low as 2.5V, while drawing less than 1.35 mA of quiescent current. The MCP6021 is available in standard 8-lead PDIP, SOIC and TSSOP packages. AEC-Q100 Grade 1 qualification is available for this device
Корпус | SOT-23 |
Количество каналов | 1 |
Aol | 110 дБ |
Automotive Recommended | Yes |
CMRR Min | 74 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 10000 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 8.7 nV/rt(Hz) |
Iq Max | 1350 µA |
Iq Typical | 1000 µA |
Isc | 30 мА |
Lead Count | 5 |
Operating Voltage Range | 2.5 - 5.5 В |
PM | 65 deg |
PSRR Min | 74 дБ |
Package Width | - |
Rail-To-Rail | In/Out |
Скорость нарастания | 7 V/µS |
Unity Gain Stable | Yes |
Vos Max | 250 µV |
ΔVos/ΔTa | 3.5 µV/°C |
MCP6021R MCP6022 MCP6023 MCP6024
Серия: MCP6021 (16)
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6021TE/OTVAO, MCP6021T E/OTVAO
