Datasheet Microchip MCP6281R — Даташит
СерияMCP6281R
The Microchip Technology MCP6281/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current.
Datasheet MCP6281, MCP6281R, MCP6282, MCP6283, MCP6284, MCP6285
PDF, 644 Кб, Язык: анг., Файл опубликован: 10 фев 2010, Страниц: 36
Операционные усилители Single 5 MHz OP E temp rvs pinout
LifeElectronics
MCP6281R
This family has a 5 MHz Gain Bandwidth Product (GBWP) and a 65° phase margin. This family also operates from a single supply voltage as low as 2.2V, while drawing 450 µA (typical) quiescent current. Additionally, the MCP6281/1R/2/3/4/5 supports rail-to-rail input and output swing, with a common mode input voltage range of VDD + 300mV to VSS – 300 mV. This family of operational amplifiers is designed with Microchip’s advanced CMOS process. The MCP6285 has a Chip Select (CS) input for dual op amps in an 8-pin package. This device is manufactured by cascading the two op amps (the output of op amp A connected to the non-inverting input of op amp B). The CS input puts the device in Low-power mode. The MCP6281/1R/2/3/4/5 family operates over the Extended Temperature Range of -40°C to +125°C. It also has a power supply range of 2.2V to 6.0V.
MCP6281RT-E/OT
MCP6281RT-E/OT
N1
КорпусSOT-23
Parameters / ModelsMCP6281RT-E/OT
Aol, дБ110
Automotive RecommendedYes
CMRR Min, дБ65
Количество каналов1
DescriptionLinear Op Amps
EMI ProtectionNo
GBWP, kHz5000
Ib, pA1
Input Voltage Noise Density, nV/rt(Hz)16
Iq Max, µA570
Iq Typical, µA445
Isc, мА25
Lead Count5
Operating Voltage Range, В2.2 - 6.0
PM, deg65
PSRR Min, дБ70
Package Width-
Rail-To-RailIn/Out
Скорость нарастания, V/µS2.5
Unity Gain StableYes
Vos Max, µV3000
ΔVos/ΔTa, µV/°C1.7
MCP6281 MCP6282 MCP6283 MCP6284 MCP6285
Серия: MCP6281R (1)
  • Amplifiers and Linear > Operational Amplifiers > General Purpose
На английском языке: Datasheet Microchip MCP6281R
