Datasheet Microchip MCP6284-E/SLVAO — Даташит
Производитель | Microchip |
Серия | MCP6284 |
Модель | MCP6284-E/SLVAO |
The Microchip Technology MCP6281/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current.
5 предложений от 2 поставщиков IC OPAMP GP 4 CIRCUIT 14SOIC | |||
MCP6284-E/SLVAO Microchip | от 137 ₽ | ||
MCP6284-E/SLVAO Microchip | по запросу |
This family has a 5 MHz Gain Bandwidth Product (GBWP) and a 65° phase margin. This family also operates from a single supply voltage as low as 2.2V, while drawing 450 µA (typical) quiescent current. Additionally, the MCP6281/1R/2/3/4/5 supports rail-to-rail input and output swing, with a common mode input voltage range of VDD + 300mV to VSS – 300 mV. This family of operational amplifiers is designed with Microchip’s advanced CMOS process. The MCP6285 has a Chip Select (CS) input for dual op amps in an 8-pin package. This device is manufactured by cascading the two op amps (the output of op amp A connected to the non-inverting input of op amp B). The CS input puts the device in Low-power mode. The MCP6281/1R/2/3/4/5 family operates over the Extended Temperature Range of -40°C to +125°C. It also has a power supply range of 2.2V to 6.0V.
Корпус | SOIC |
Количество каналов | 4 |
Aol | 110 дБ |
Automotive Recommended | Yes |
CMRR Min | 65 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 5000 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 16 nV/rt(Hz) |
Iq Max | 570 µA |
Iq Typical | 445 µA |
Isc | 25 мА |
Lead Count | 14 |
Operating Voltage Range | 2.2 - 6.0 В |
PM | 65 deg |
PSRR Min | 70 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | In/Out |
Скорость нарастания | 2.5 V/µS |
Unity Gain Stable | Yes |
Vos Max | 3000 µV |
ΔVos/ΔTa | 1.7 µV/°C |
MCP6281 MCP6281R MCP6282 MCP6283 MCP6285
- Amplifiers and Linear > Operational Amplifiers > General Purpose
MCP6284E/SLVAO, MCP6284 E/SLVAO
