HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Microchip MCP6284T-E/SLVAO — Даташит
СерияMCP6284
МодельMCP6284T-E/SLVAO
The Microchip Technology MCP6281/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current.
Datasheet MCP6281, MCP6281R, MCP6282, MCP6283, MCP6284, MCP6285
PDF, 644 Кб, Язык: анг., Файл опубликован: 10 фев 2010, Страниц: 36
Acme Chip
MCP6284T-E/SLVAO
Электромеханические реле Hongfa – надежность и качество 19 января 2023
This family has a 5 MHz Gain Bandwidth Product (GBWP) and a 65° phase margin. This family also operates from a single supply voltage as low as 2.2V, while drawing 450 µA (typical) quiescent current. Additionally, the MCP6281/1R/2/3/4/5 supports rail-to-rail input and output swing, with a common mode input voltage range of VDD + 300mV to VSS – 300 mV. This family of operational amplifiers is designed with Microchip’s advanced CMOS process. The MCP6285 has a Chip Select (CS) input for dual op amps in an 8-pin package. This device is manufactured by cascading the two op amps (the output of op amp A connected to the non-inverting input of op amp B). The CS input puts the device in Low-power mode. The MCP6281/1R/2/3/4/5 family operates over the Extended Temperature Range of -40°C to +125°C. It also has a power supply range of 2.2V to 6.0V.
КорпусSOIC
Количество каналов4
Aol110 дБ
Automotive RecommendedYes
CMRR Min65 дБ
DescriptionLinear Op Amps
EMI ProtectionNo
GBWP5000 kHz
Ib1 pA
Input Voltage Noise Density16 nV/rt(Hz)
Iq Max570 µA
Iq Typical445 µA
Isc25 мА
Lead Count14
Operating Voltage Range2.2 - 6.0 В
PM65 deg
PSRR Min70 дБ
Package Width.150In(3.90mm)
Rail-To-RailIn/Out
Скорость нарастания2.5 V/µS
Unity Gain StableYes
Vos Max3000 µV
ΔVos/ΔTa1.7 µV/°C
MCP6281 MCP6281R MCP6282 MCP6283 MCP6285
  • Amplifiers and Linear > Operational Amplifiers > General Purpose
MCP6284TE/SLVAO, MCP6284T E/SLVAO
На английском языке: Datasheet Microchip MCP6284T-E/SLVAO
