Datasheet Linear Technology LTC1403A — Даташит
СерияLTC1403A
Serial 14-Bit, 2.8Msps Sampling ADCs with Shutdown
Datasheet LTC1403, LTC1403A
PDF, 370 Кб, Язык: анг., Файл закачен: 16 авг 2017, Страниц: 22
Serial 12-Bit/14-Bit, 2.8Msps Sampling ADCs with Shutdown
ТаймЧипс
LTC1403Aпо запросу
LTC1403ACMSE#PBFLTC1403ACMSE#TRPBFLTC1403AHMSE#PBFLTC1403AHMSE#TRPBFLTC1403AIMSE#PBFLTC1403AIMSE#TRPBF
N123456
КорпусMS-10E
Габаритный чертеж корпуса
MS-10E
MS-10E
MS-10E
MS-10E
MS-10E
Код корпусаMSEMSEMSEMSEMSEMSE
Индекс корпуса05-08-166405-08-166405-08-166405-08-166405-08-166405-08-1664
Количество выводов101010101010
Parameters / ModelsLTC1403ACMSE#PBFLTC1403ACMSE#TRPBFLTC1403AHMSE#PBFLTC1403AHMSE#TRPBFLTC1403AIMSE#PBFLTC1403AIMSE#TRPBF
ADC INL, LSB0.50.50.50.50.50.5
ADCs111111
АрхитектураSARSARSARSARSARSAR
Bipolar/Unipolar InputUnipolarUnipolarUnipolarUnipolarUnipolarUnipolar
Bits, bits141414141414
Количество каналов111111
DNL, LSB0.60.60.60.60.60.6
Demo BoardsDC1082A-DDC1082A-DDC1082A-DDC1082A-DDC1082A-DDC1082A-D
Экспортный контрольнетнетнетнетнетнет
I/OSerial SPISerial SPISerial SPISerial SPISerial SPISerial SPI
Input DriveDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully Differential
Input Span0V to 2.5V0V to 2.5V0V to 2.5V0V to 2.5V0V to 2.5V0V to 2.5V
Internal Referenceдададададада
Latency111111
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от -40 до 125от -40 до 125от -40 до 85от -40 до 85
Power, mW121212121212
SFDR, дБ909090909090
SINAD, дБ73.573.573.573.573.573.5
SNR, дБ73.573.573.573.573.573.5
Simultaneousнетнетнетнетнетнет
Speed, ksps280028002800280028002800
Диапазон напряжения питания3V3V3V3V3V3V
THD dB, дБ-90-90-90-90-90-90
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
LTC1403 LTC1403
  • Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Single Channel ADCs
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) ADCs
На английском языке: Datasheet Linear Technology LTC1403A
Публикации по теме
