Datasheet Linear Technology LTC2358-16 — Даташит
Серия | LTC2358-16 |
Buffered Octal, 16-Bit, 200ksps/Ch Differential ±10.24V ADC with 30VP-P Common Mode Range
LTC2358-16 - Buffered Octal, 16-Bit, 200ksps/Ch Differential ±10.24V ADC with 30VP-P Common Mode Range
PDF, 2.3 Мб, Файл закачен: 20 авг 2017
Купить LTC2358 на РадиоЛоцман.Цены — от 2 658 до 8 339 ₽ IC ADC 16BIT SAR 48LQFP | |||
LTC2358CLX-16 Linear Technology | от 2 658 ₽ | ||
LTC2358CLX-18 Analog Devices | 8 339 ₽ |
LTC2358CLX-16#PBF | LTC2358HLX-16#PBF | LTC2358ILX-16#PBF | |
N | 1 | 2 | 3 |
Корпус | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса |
Код корпуса | LX | LX | LX |
Индекс корпуса | 05-08-1760 | 05-08-1760 | 05-08-1760 |
Количество выводов | 48 | 48 | 48 |
Parameters / Models | LTC2358CLX-16#PBF | LTC2358HLX-16#PBF | LTC2358ILX-16#PBF |
ADC INL, LSB | 0.3 | 0.3 | 0.3 |
ADCs | 1 | 1 | 1 |
Архитектура | SAR | SAR | SAR |
Bipolar/Unipolar Input | Bipolar, Unipolar, True Bipolar | Bipolar, Unipolar, True Bipolar | Bipolar, Unipolar, True Bipolar |
Bits, bits | 16 | 16 | 16 |
Количество каналов | 8 | 8 | 8 |
DNL, LSB | 0.1 | 0.1 | 0.1 |
Demo Boards | DC2365A-E | DC2365A-E | DC2365A-E |
Design Tools | Linduino File | Linduino File | Linduino File |
Экспортный контроль | нет | нет | нет |
Основные особенности | Buffered Inputs, Simultaneous Sampling, SoftSpan | Buffered Inputs, Simultaneous Sampling, SoftSpan | Buffered Inputs, Simultaneous Sampling, SoftSpan |
I/O | Serial SPI, Serial LVDS | Serial SPI, Serial LVDS | Serial SPI, Serial LVDS |
Input Drive | Differential, Single-Ended | Differential, Single-Ended | Differential, Single-Ended |
Input Span | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V |
Internal Reference | да | да | да |
Рабочий диапазон температур, °C | от 0 до 70 | от -40 до 125 | от -40 до 85 |
Power, mW | 219 | 219 | 219 |
SFDR, дБ | 113 | 113 | 113 |
SINAD, дБ | 94.1 | 94.1 | 94.1 |
SNR, дБ | 94.2 | 94.2 | 94.2 |
Simultaneous | да | да | да |
Speed, ksps | 200 | 200 | 200 |
Диапазон напряжения питания | 1.71V to 5V | 1.71V to 5V | 1.71V to 5V |
THD dB, дБ | -111 | -111 | -111 |
- Buffered ADC Family Eliminates Signal Conditioning Complexity &mdash AN167PDF, 1.3 Мб, Файл опубликован: 20 сен 2017Выписка из документа
Серия: LTC2358-16 (3)
- Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Simultaneous Sampling ADCs | Multi Channel ADCs
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) ADCs
