Datasheet Linear Technology LT3091 — Даташит
Серия | LT3091 |
- 36V, 1.5A Negative Linear Regulator with Programmable Current Limit
Datasheet LT3091
PDF, 756 Кб, Язык: анг., Файл закачен: 2 сен 2017, Страниц: 40
–36V, 1.5A Negative Linear Regulator with Programmable Current Limit
Купить LT3091 на РадиоЛоцман.Цены — от 252 до 1 179 ₽ 26 предложений от 15 поставщиков Linear Voltage Regulator IC Negative Adjustable 1 Output 1.5A 16-TSSOP-EP | |||
LT3091EFE#PBF Analog Devices | 252 ₽ | ||
LT3091EDE#TRPBF Linear Technology | 321 ₽ | ||
LT1371IR LT1370HVCR LT1374CR LT1076CR-5 LT1580CR-2.5 LT1076HVCR LT1513-2CR LT1076CR LT1206CR LT3091IR LT1506CR TO263-7 | 324 ₽ |
Parameters / Models | LT3091EDE#PBF | LT3091EDE#TRPBF | LT3091EFE#PBF | LT3091EFE#TRPBF | LT3091ER#PBF | LT3091ER#TRPBF | LT3091ET7#PBF | LT3091HDE#PBF | LT3091HDE#TRPBF | LT3091HFE#PBF | LT3091HFE#TRPBF | LT3091HR#PBF | LT3091HR#TRPBF | LT3091HT7#PBF | LT3091IDE#PBF | LT3091IDE#TRPBF | LT3091IFE#PBF | LT3091IFE#TRPBF | LT3091IR#PBF | LT3091IR#TRPBF | LT3091IT7#PBF | LT3091MPDE#PBF | LT3091MPDE#TR | LT3091MPDE#TRPBF | LT3091MPFE#PBF | LT3091MPFE#TRPBF | LT3091MPR#PBF | LT3091MPR#TRPBF | LT3091MPT7 | LT3091MPT7#PBF |
Demo Boards | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A | DC2276A |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown | Current Source Reference, Cable Drop Compensation, Output Current Monitor, Shutdown |
Isupply, мА | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Number of Supplies | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Vin Max, В | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 | -1.5 |
Vin Min, В | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 | -36 |
LT3091EDE#PBF | LT3091EDE#TRPBF | LT3091EFE#PBF | LT3091EFE#TRPBF | LT3091ER#PBF | LT3091ER#TRPBF | LT3091ET7#PBF | LT3091HDE#PBF | LT3091HDE#TRPBF | LT3091HFE#PBF | LT3091HFE#TRPBF | LT3091HR#PBF | LT3091HR#TRPBF | LT3091HT7#PBF | LT3091IDE#PBF | LT3091IDE#TRPBF | LT3091IFE#PBF | LT3091IFE#TRPBF | LT3091IR#PBF | LT3091IR#TRPBF | LT3091IT7#PBF | LT3091MPDE#PBF | LT3091MPDE#TR | LT3091MPDE#TRPBF | LT3091MPFE#PBF | LT3091MPFE#TRPBF | LT3091MPR#PBF | LT3091MPR#TRPBF | LT3091MPT7 | LT3091MPT7#PBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Не совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Не совместим | Совместим |
Статьи
- 1.5A, Negative Regulator Expands Family of Current-Reference Linear Regulators &mdash LT JournalPDF, 453 Кб, Файл опубликован: 14 апр 2016Выписка из документа
Серия: LT3091 (30)
- LT3091EDE#PBF LT3091EDE#TRPBF LT3091EFE#PBF LT3091EFE#TRPBF LT3091ER#PBF LT3091ER#TRPBF LT3091ET7#PBF LT3091HDE#PBF LT3091HDE#TRPBF LT3091HFE#PBF LT3091HFE#TRPBF LT3091HR#PBF LT3091HR#TRPBF LT3091HT7#PBF LT3091IDE#PBF LT3091IDE#TRPBF LT3091IFE#PBF LT3091IFE#TRPBF LT3091IR#PBF LT3091IR#TRPBF LT3091IT7#PBF LT3091MPDE#PBF LT3091MPDE#TR LT3091MPDE#TRPBF LT3091MPFE#PBF LT3091MPFE#TRPBF LT3091MPR#PBF LT3091MPR#TRPBF LT3091MPT7 LT3091MPT7#PBF
- Power Management > LDO Linear Regulators > Negative Linear Regulators (LDO) | LDO Plus | Extended Temperature (H & MP) Linear Regulators
- Monitor, Control and Protection > Cable Drop Compensation
