Datasheet Linear Technology LT1767 — Даташит
Серия | LT1767 |
Monolithic 1.5A, 1.25MHz Step-Down Switching Regulators
Datasheet LT1767, LT1767-1.8, LT1767-2.5, LT1767-3.3, LT1767-5
PDF, 441 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 20
Купить LT1767 на РадиоЛоцман.Цены — от 150 до 2 691 ₽ 27 предложений от 22 поставщиков Conv DC-DC 3V to 25V Step Down Single-Out 3.3V 1.5A 8Pin MSOP | |||
LT1767EMS8 Analog Devices | от 150 ₽ | ||
LT1767EMS8-3.3 Analog Devices | 225 ₽ | ||
LT1767ES8 Linear Technology | по запросу | ||
LT1767EMS8-5 Linear Technology | по запросу |
Parameters / Models | LT1767EMS8#PBF | LT1767EMS8#TRPBF | LT1767EMS8-1.8#PBF | LT1767EMS8-1.8#TRPBF | LT1767EMS8-2.5#PBF | LT1767EMS8-2.5#TRPBF | LT1767EMS8-3.3#PBF | LT1767EMS8-3.3#TRPBF | LT1767EMS8-5#PBF | LT1767EMS8-5#TRPBF | LT1767EMS8E#PBF | LT1767EMS8E#TRPBF | LT1767EMS8E-1.8#PBF | LT1767EMS8E-1.8#TRPBF | LT1767EMS8E-2.5#PBF | LT1767EMS8E-2.5#TRPBF | LT1767EMS8E-3.3#PBF | LT1767EMS8E-3.3#TRPBF | LT1767EMS8E-5#PBF | LT1767EMS8E-5#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A | DC502A |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization |
Тактовая частота, kHz | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 | 1250 |
Frequency Sync Range | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz | 1.4MHz - 2MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Isupply, мА | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 |
Выходной ток, A | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 |
Vin Min, В | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Vout Max, В | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Vout Maximum | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN | .80VIN |
Vout Min, В | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Vref Accuracy Over Temp, % | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
LT1767EMS8#PBF | LT1767EMS8#TRPBF | LT1767EMS8-1.8#PBF | LT1767EMS8-1.8#TRPBF | LT1767EMS8-2.5#PBF | LT1767EMS8-2.5#TRPBF | LT1767EMS8-3.3#PBF | LT1767EMS8-3.3#TRPBF | LT1767EMS8-5#PBF | LT1767EMS8-5#TRPBF | LT1767EMS8E#PBF | LT1767EMS8E#TRPBF | LT1767EMS8E-1.8#PBF | LT1767EMS8E-1.8#TRPBF | LT1767EMS8E-2.5#PBF | LT1767EMS8E-2.5#TRPBF | LT1767EMS8E-3.3#PBF | LT1767EMS8E-3.3#TRPBF | LT1767EMS8E-5#PBF | LT1767EMS8E-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- 1.25MHz, 1.5A, MS8 Monolithic Step-Down Converter Keeps Switching Noise above the Signal Spectrum &mdash LT JournalPDF, 147 Кб, Файл опубликован: 1 ноя 2000Выписка из документа
Серия: LT1767 (20)
- LT1767EMS8#PBF LT1767EMS8#TRPBF LT1767EMS8-1.8#PBF LT1767EMS8-1.8#TRPBF LT1767EMS8-2.5#PBF LT1767EMS8-2.5#TRPBF LT1767EMS8-3.3#PBF LT1767EMS8-3.3#TRPBF LT1767EMS8-5#PBF LT1767EMS8-5#TRPBF LT1767EMS8E#PBF LT1767EMS8E#TRPBF LT1767EMS8E-1.8#PBF LT1767EMS8E-1.8#TRPBF LT1767EMS8E-2.5#PBF LT1767EMS8E-2.5#TRPBF LT1767EMS8E-3.3#PBF LT1767EMS8E-3.3#TRPBF LT1767EMS8E-5#PBF LT1767EMS8E-5#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
