Datasheet Linear Technology LT1952 — Даташит
Серия | LT1952 |
Single Switch Synchronous Forward Controller
Datasheet LT1952, LT1952-1
PDF, 371 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 28
Купить LT1952 на РадиоЛоцман.Цены — от 254 до 1 634 ₽ 33 предложений от 22 поставщиков Forward Converter Regulator Positive, Isolation Capable Output Step-Up/Step-Down DC-DC Controller IC 16-SSOP | |||
LT1952EGN#PBF Analog Devices | 254 ₽ | ||
LT1952EGN-1 Linear Technology | 283 ₽ | ||
LT1952-1 | по запросу | ||
LT1952IGN-1 | по запросу |
LT1952EGN#PBF | LT1952EGN#TRPBF | LT1952IGN#PBF | LT1952IGN#TRPBF | LT1952MPGN#PBF | LT1952MPGN#TRPBF | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | SSOP-16 Габаритный чертеж корпуса | SSOP-16 Габаритный чертеж корпуса | SSOP-16 Габаритный чертеж корпуса | SSOP-16 Габаритный чертеж корпуса | SSOP-16 Габаритный чертеж корпуса | SSOP-16 Габаритный чертеж корпуса |
Код корпуса | GN | GN | GN | GN | GN | GN |
Индекс корпуса | 05-08-1641 (GN16) | 05-08-1641 (GN16) | 05-08-1641 (GN16) | 05-08-1641 (GN16) | 05-08-1641 (GN16) | 05-08-1641 (GN16) |
Количество выводов | 16 | 16 | 16 | 16 | 16 | 16 |
Parameters / Models | LT1952EGN#PBF | LT1952EGN#TRPBF | LT1952IGN#PBF | LT1952IGN#TRPBF | LT1952MPGN#PBF | LT1952MPGN#TRPBF |
Demo Boards | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H | DC1317A-A,DC1317A-B,DC1317A-C,DC1317A-E,DC1317A-F,DC759A,DC830A,DC968A-A,DC968A-B,DC968A-C,DC968A-D,DC1317A-G,DC1317A-D,DC1317A-H |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет |
Основные особенности | Resistor Set Frequency, External Synchronization | Resistor Set Frequency, External Synchronization | Resistor Set Frequency, External Synchronization | Resistor Set Frequency, External Synchronization | Resistor Set Frequency, External Synchronization | Resistor Set Frequency, External Synchronization |
Тактовая частота, kHz | 500 | 500 | 500 | 500 | 500 | 500 |
Frequency Adjust Range | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz |
Frequency Sync Range | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz | 100kHz - 500kHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 240 | 240 | 240 | 240 | 240 | 240 |
Isupply, мА | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 | 5.2 |
Monolithic | нет | нет | нет | нет | нет | нет |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 |
Polyphase | нет | нет | нет | нет | нет | нет |
Switch Current, A | 10 | 10 | 10 | 10 | 10 | 10 |
Synchronous | да | да | да | да | да | да |
Topology | Forward, Flyback | Forward, Flyback | Forward, Flyback | Forward, Flyback | Forward, Flyback | Forward, Flyback |
Vin Max, В | 25 | 25 | 25 | 25 | 25 | 25 |
Vin Min, В | 15.75 | 15.75 | 15.75 | 15.75 | 15.75 | 15.75 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- Simple Circuit Replaces and Improves on Power Modules at Less Than Half the Price &mdash DN347PDF, 80 Кб, Файл опубликован: 4 сен 2004Выписка из документа
Серия: LT1952 (6)
- Power Management > Switching Regulator > Flyback, Forward and Isolated Controllers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
