Datasheet Linear Technology LT3579-1 — Даташит
СерияLT3579-1
6A Boost/Inverting DC/DC Converter with Fault Protection
LT3579: 6A Boost/Inverting DC/DC Converter with Fault Protection Data Sheet
PDF, 589 Кб, Файл закачен: 18 сен 2017
ТаймЧипс
LT3579-1
LT3579 & LT3579-1: 5-10Vin [email protected]
LT3579EFE-1#PBFLT3579EFE-1#TRPBFLT3579EUFD-1#PBFLT3579EUFD-1#TRPBFLT3579IFE-1#PBFLT3579IFE-1#TRPBFLT3579IUFD-1#PBFLT3579IUFD-1#TRPBF
N12345678
КорпусTSSOP-20
Габаритный чертеж корпуса
TSSOP-20
4x5 QFN-20
4x5 QFN-20
TSSOP-20
TSSOP-20
4x5 QFN-20
4x5 QFN-20
Код корпусаFEFEUFDUFDFEFEUFDUFD
Индекс корпуса05-08-1663 (CB)05-08-1663 (CB)05-08-171105-08-171105-08-1663 (CB)05-08-1663 (CB)05-08-171105-08-1711
Количество выводов2020202020202020
Parameters / ModelsLT3579EFE-1#PBFLT3579EFE-1#TRPBFLT3579EUFD-1#PBFLT3579EUFD-1#TRPBFLT3579IFE-1#PBFLT3579IFE-1#TRPBFLT3579IUFD-1#PBFLT3579IUFD-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661ADC1514A,DC1661A
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set FrequencyOutput Short Circuit Protection, PolyPhase, External Synchronization, Resistor Set Frequency
Тактовая частота, kHz25002500250025002500250025002500
Frequency Adjust Range200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz
Frequency Sync Range200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz200kHz - 2.5MHz
Isupply, мА1.91.91.91.91.91.91.91.9
Monolithicдададададададада
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Over Voltage Protection, В4040404040404040
Switch Current, A7.57.57.57.57.57.57.57.5
Synchronousнетнетнетнетнетнетнетнет
TopologyBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, Sepic
Topology 1Boost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, SepicBoost, Inverting, Sepic
Vin Max, В1616161616161616
Vin Min, В2.52.52.52.52.52.52.52.5
Vin Min Startup, В2.52.52.52.52.52.52.52.5
Vout Max, В4242424242424242
Vout Maximum42V42V42V42V42V42V42V42V
Vswitch Max, В4242424242424242
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT3579
Статьи
  • Two High Power Monolithic Switching Regulators Include Integrated 6A, 42V or 3.3A, 42V Power Switches &mdash LT Journal
    PDF, 1.8 Мб, Файл опубликован: 18 янв 2011
  • Power Management > Switching Regulator > Inverting Regulators | LCD/CCD/OLED Bias | SEPIC Regulators | Flyback, Forward and Isolated Controllers
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
На английском языке: Datasheet Linear Technology LT3579-1
