Datasheet Linear Technology LT3758A — Даташит
СерияLT3758A
High Input Voltage, Boost, Flyback, SEPIC and Inverting Controller
LT3758: High Input Voltage, Boost, Flyback, SEPIC and Inverting Controller Data Sheet
PDF, 862 Кб, Файл закачен: 19 сен 2017
LT3758A: 18-72Vin 24Vout@1A
LT3758AEDD#PBFLT3758AEDD#TRPBFLT3758AEMSE#PBFLT3758AEMSE#TRPBFLT3758AHMSE#PBFLT3758AHMSE#TRPBFLT3758AIDD#PBFLT3758AIDD#TRPBFLT3758AIMSE#PBFLT3758AIMSE#TRPBFLT3758AMPMSE#PBFLT3758AMPMSE#TRPBF
N123456789101112
Корпус3x3 DFN-10
Габаритный чертеж корпуса
3x3 DFN-10
MS-10E
MS-10E
MS-10E
MS-10E
3x3 DFN-10
3x3 DFN-10
MS-10E
MS-10E
MS-10E
MS-10E
Код корпусаDDDDMSEMSEMSEMSEDDDDMSEMSEMSEMSE
Индекс корпуса05-08-169905-08-169905-08-166405-08-166405-08-166405-08-166405-08-169905-08-169905-08-166405-08-166405-08-166405-08-1664
Количество выводов101010101010101010101010
Parameters / ModelsLT3758AEDD#PBFLT3758AEDD#TRPBFLT3758AEMSE#PBFLT3758AEMSE#TRPBFLT3758AHMSE#PBFLT3758AHMSE#TRPBFLT3758AIDD#PBFLT3758AIDD#TRPBFLT3758AIMSE#PBFLT3758AIMSE#TRPBFLT3758AMPMSE#PBFLT3758AMPMSE#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342BDC1412A,DC1342B
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External SynchronizationResistor Set Frequency, External Synchronization
Тактовая частота, kHz100010001000100010001000100010001000100010001000
Frequency Adjust Range100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz
Frequency Sync Range100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz100kHz - 1MHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА666666666666
Isupply, мА1.61.61.61.61.61.61.61.61.61.61.61.6
Max Phases111111111111
Monolithicнетнетнетнетнетнетнетнетнетнетнетнет
Количество выходов111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнет
Sense ResistorRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsense
Switch Current, A252525252525252525252525
Synchronousнетнетнетнетнетнетнетнетнетнетнетнет
TopologyBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, InvertingBoost, Flyback, Sepic, Inverting
Vin Max, В100100100100100100100100100100100100
Vin Min, В5.55.55.55.55.55.55.55.55.55.55.55.5
Vin Min Startup, В5.55.55.55.55.55.55.55.55.55.55.55.5
Vout Max, В350350350350350350350350350350350350
Vout MaximumLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external componentsLimited by external components
Vout Min, В1.61.61.61.61.61.61.61.61.61.61.61.6
Vswitch Max, В350350350350350350350350350350350350
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • 2-Wire Virtual Remote Sensing for Voltage Regulators - Clairvoyance Marries Remote Sensing &mdash AN126
    PDF, 1.4 Мб, Файл опубликован: 1 окт 2010
    Wires and connectors have resistance. This simple, unavoidable truth dictates that a power source’s remote load voltage will be less than the source’s output voltage. Traditional methods for countering this include increasing the power source voltage and "4-wire" remote voltage sensing. Both have limitations. A new IC based approach achieves "virtual" remote sensing at the load without adding the usual two extra sense wires. Numerous circuit examples show the IC working with various voltage regulators and remote loads. Appendices detail IC internal operation and design guidelines for applying the part in any regulator circuit.
Статьи
  • Two New Controllers for Boost, Flyback, SEPIC and Inverting DC/DC Converters Accept Inputs up to 100V &mdash LT Journal
    PDF, 457 Кб, Файл опубликован: 1 июн 2009
  • Power Management > Switching Regulator > SEPIC Regulators | Flyback, Forward and Isolated Controllers | Inverting Regulators
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LT3758A
