HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Linear Technology LT3791-1 — Даташит
СерияLT3791-1
60V 4-Switch Synchronous Buck-Boost Controller
Datasheet LT3791-1
PDF, 312 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 26
LT3791-1: 3-55Vin 12Vout@5A
LT3791EFE-1#PBFLT3791EFE-1#TRPBFLT3791HFE-1#PBFLT3791HFE-1#TRPBFLT3791IFE-1#PBFLT3791IFE-1#TRPBFLT3791MPFE-1#PBFLT3791MPFE-1#TRPBF
N12345678
КорпусTSSOP-38
Габаритный чертеж корпуса
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
TSSOP-38
Код корпусаFEFEFEFEFEFEFEFE
Индекс корпуса05-08-177205-08-177205-08-177205-08-177205-08-177205-08-177205-08-177205-08-1772
Количество выводов3838383838383838
Parameters / ModelsLT3791EFE-1#PBFLT3791EFE-1#TRPBFLT3791HFE-1#PBFLT3791HFE-1#TRPBFLT3791IFE-1#PBFLT3791IFE-1#TRPBFLT3791MPFE-1#PBFLT3791MPFE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output DisconnectResistor Set Frequency, External Synchronization, Input Current Regulation, Output Current Regulation, Input Current Monitor, Output Current Monitor, Output Disconnect
Тактовая частота, kHz700700700700700700700700
Frequency Adjust Range200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz
Frequency Sync Range200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz200kHz - 700kHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА0.10.10.10.10.10.10.10.1
Isupply, мА33333333
Max Phases1212121212121212
Monolithicнетнетнетнетнетнетнетнет
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A1010101010101010
Polyphaseдададададададада
Sense ResistorRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsense
Synchronousдададададададада
TopologyBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, BuckBuck-Boost, Buck
Vin Max, В6060606060606060
Vin Min, В4.74.74.74.74.74.74.74.7
Vout Max, В6060606060606060
Vout Maximum60V60V60V60V60V60V60V60V
Vout Min, В1.21.21.21.21.21.21.21.2
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
Статьи
  • 60V, 4-Switch Synchronous Buck-Boost Controller Regulates Voltage from Wide Ranging Inputs and Charges Batteries at 98.5% Efficiency at 100W+ &mdash LT Journal
    PDF, 2.7 Мб, Файл опубликован: 18 окт 2012
  • Power Management > Switching Regulator > Buck-Boost Regulators > External Power Switch Buck-Boost
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LT3791-1
Публикации по теме
