Datasheet Linear Technology LT3990 — Даташит
Серия | LT3990 |
62V, 350mA Step-Down Regulator with 2.5µA Quiescent Current and Integrated Diodes
Datasheet LT3990, LT3990-3.3, LT3990-5
PDF, 307 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 22
62V, 350mA Step-Down Regulator with 2.5μA Quiescent Current and Integrated Diodes
Купить LT3990 на РадиоЛоцман.Цены — от 216 до 3 071 ₽ 41 предложений от 25 поставщиков 62V, 350mA Step-Down Regulator with 2.5µA Quiescent Current and Integrated Diodes_x0000__x0000_ | |||
LT3990HMSE#TRPBF Analog Devices | от 216 ₽ | ||
LT3990EDD#PBF Analog Devices | 224 ₽ | ||
LT3990EDD PBF Linear Technology | по запросу | ||
LT3990IDD#TRPBF Linear Technology | по запросу |
Parameters / Models | LT3990EDD#PBF | LT3990EDD#TRPBF | LT3990EMSE#PBF | LT3990EMSE#TRPBF | LT3990EMSE-3.3#PBF | LT3990EMSE-3.3#TRPBF | LT3990EMSE-5#PBF | LT3990EMSE-5#TRPBF | LT3990HMSE#PBF | LT3990HMSE#TRPBF | LT3990HMSE-3.3#PBF | LT3990HMSE-3.3#TRPBF | LT3990HMSE-5#PBF | LT3990HMSE-5#TRPBF | LT3990IDD#PBF | LT3990IDD#TRPBF | LT3990IMSE#PBF | LT3990IMSE#TRPBF | LT3990IMSE-3.3#PBF | LT3990IMSE-3.3#TRPBF | LT3990IMSE-5#PBF | LT3990IMSE-5#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A | DC1471A |
Design Tools | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model | LTspice File,LTpowerCAD Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good | Burst Mode, Resistor Set Frequency, Power Good |
Тактовая частота, kHz | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 |
Frequency Adjust Range | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz | 200kHz - 2.2MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Isupply, мА | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 | 0.0017 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vin Min, В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Vout Max, В | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 |
Vout Maximum | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V | 25V |
Vout Min, В | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 | 1.21 |
Vref Accuracy Over Temp, % | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 |
LT3990EDD#PBF | LT3990EDD#TRPBF | LT3990EMSE#PBF | LT3990EMSE#TRPBF | LT3990EMSE-3.3#PBF | LT3990EMSE-3.3#TRPBF | LT3990EMSE-5#PBF | LT3990EMSE-5#TRPBF | LT3990HMSE#PBF | LT3990HMSE#TRPBF | LT3990HMSE-3.3#PBF | LT3990HMSE-3.3#TRPBF | LT3990HMSE-5#PBF | LT3990HMSE-5#TRPBF | LT3990IDD#PBF | LT3990IDD#TRPBF | LT3990IMSE#PBF | LT3990IMSE#TRPBF | LT3990IMSE-3.3#PBF | LT3990IMSE-3.3#TRPBF | LT3990IMSE-5#PBF | LT3990IMSE-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LT3990 (22)
- LT3990EDD#PBF LT3990EDD#TRPBF LT3990EMSE#PBF LT3990EMSE#TRPBF LT3990EMSE-3.3#PBF LT3990EMSE-3.3#TRPBF LT3990EMSE-5#PBF LT3990EMSE-5#TRPBF LT3990HMSE#PBF LT3990HMSE#TRPBF LT3990HMSE-3.3#PBF LT3990HMSE-3.3#TRPBF LT3990HMSE-5#PBF LT3990HMSE-5#TRPBF LT3990IDD#PBF LT3990IDD#TRPBF LT3990IMSE#PBF LT3990IMSE#TRPBF LT3990IMSE-3.3#PBF LT3990IMSE-3.3#TRPBF LT3990IMSE-5#PBF LT3990IMSE-5#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
