Datasheet Linear Technology LT8330 — Даташит
Серия | LT8330 |
Low IQ Boost/SEPIC/Inverting Converter with 1A, 60V Switch
Datasheet LT8330
PDF, 1.7 Мб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 24
Купить LT8330 на РадиоЛоцман.Цены — от 211 до 1 128 ₽ 25 предложений от 13 поставщиков Boost, SEPIC Switching Regulator IC Positive or Negative, Isolation Capable Adjustable 1.6V, -0.8V 1 Output 1A 8-WFDFN Exposed Pad | |||
LT8330IDDB#TRPBF Analog Devices | от 211 ₽ | ||
LT8330EDDB#TRMPBF Analog Devices | 219 ₽ | ||
LT8330EDDB#TRPBF Analog Devices | от 1 128 ₽ | ||
LT8330IDDB#TRMPBF Analog Devices | по запросу |
Parameters / Models | LT8330EDDB#PBF | LT8330EDDB#TRMPBF | LT8330EDDB#TRPBF | LT8330ES6#PBF | LT8330ES6#TRMPBF | LT8330ES6#TRPBF | LT8330HDDB#PBF | LT8330HDDB#TRMPBF | LT8330HDDB#TRPBF | LT8330HS6#PBF | LT8330HS6#TRMPBF | LT8330HS6#TRPBF | LT8330IDDB#PBF | LT8330IDDB#TRMPBF | LT8330IDDB#TRPBF | LT8330IS6#PBF | LT8330IS6#TRMPBF | LT8330IS6#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A | DC2018A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode | Burst Mode |
Тактовая частота, kHz | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 |
Isupply, мА | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 | 0.0055 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting |
Topology 1 | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting | Boost, Sepic, Inverting |
Vin Max, В | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
Vin Min, В | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Vin Min Startup, В | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Vout Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vout Maximum | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V |
Vout Min, В | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
Vref Accuracy Over Temp, % | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Vswitch Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
LT8330EDDB#PBF | LT8330EDDB#TRMPBF | LT8330EDDB#TRPBF | LT8330ES6#PBF | LT8330ES6#TRMPBF | LT8330ES6#TRPBF | LT8330HDDB#PBF | LT8330HDDB#TRMPBF | LT8330HDDB#TRPBF | LT8330HS6#PBF | LT8330HS6#TRMPBF | LT8330HS6#TRPBF | LT8330IDDB#PBF | LT8330IDDB#TRMPBF | LT8330IDDB#TRPBF | LT8330IS6#PBF | LT8330IS6#TRMPBF | LT8330IS6#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- Low IQ, 60V Monolithic Boost/Sepic/Inverting Converter in ThinSOT or 3mm x 2mm DFN &mdash LT JournalPDF, 833 Кб, Файл опубликован: 8 фев 2016Выписка из документа
Серия: LT8330 (18)
- Power Management > Switching Regulator > Inverting Regulators | SEPIC Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > Micropower Boost | Internal Power Switch Boost
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
