Datasheet Linear Technology LT8570-1 — Даташит
СерияLT8570-1
Boost/SEPIC/Inverting DC/DC Converter with 65V Switch, Soft-Start and Synchronization
Datasheet LT8570, LT8570-1
PDF, 906 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 34
LT8570-1: 9-16Vin 48Vout@50mA
LT8570EDD-1#PBFLT8570EDD-1#TRPBFLT8570EMS8E-1#PBFLT8570EMS8E-1#TRPBFLT8570IDD-1#PBFLT8570IDD-1#TRPBFLT8570IMS8E-1#PBFLT8570IMS8E-1#TRPBF
N12345678
Корпус3x3 DFN-8
Габаритный чертеж корпуса
3x3 DFN-8
MS-8E
MS-8E
3x3 DFN-8
3x3 DFN-8
MS-8E
MS-8E
Код корпусаDDDDMS8EMS8EDDDDMS8EMS8E
Индекс корпуса05-08-169805-08-169805-08-166205-08-166205-08-169805-08-169805-08-166205-08-1662
Количество выводов88888888
Parameters / ModelsLT8570EDD-1#PBFLT8570EDD-1#TRPBFLT8570EMS8E-1#PBFLT8570EMS8E-1#TRPBFLT8570IDD-1#PBFLT8570IDD-1#TRPBFLT8570IMS8E-1#PBFLT8570IMS8E-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-BDC2297A-A,DC2297A-B
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft StartResistor Set Frequency, External Synchronization, Soft Start
Тактовая частота, kHz15001500150015001500150015001500
Frequency Adjust Range200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz
Frequency Sync Range200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz200kHz - 1.5MHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА11111111
Isupply, мА1.21.21.21.21.21.21.21.2
Max Phases11111111
Monolithicдададададададада
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Switch Current, A0.3750.3750.3750.3750.3750.3750.3750.375
Synchronousнетнетнетнетнетнетнетнет
TopologyBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, Inverting
Topology 1Boost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, InvertingBoost, Sepic, Inverting
Vin Max, В4040404040404040
Vin Min, В2.552.552.552.552.552.552.552.55
Vin Min Startup, В2.552.552.552.552.552.552.552.55
Vout Max, В6565656565656565
Vout Maximum65V65V65V65V65V65V65V65V
Vout Min, В1.2041.2041.2041.2041.2041.2041.2041.204
Vref Accuracy Over Temp, %1.31.31.31.31.31.31.31.3
Vswitch Max, В6565656565656565
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT8570 LT8570
Статьи
  • 3mm × 3mm Monolithic DC/DC Boost/Inverting Converters with 65V Power Switches &mdash LT Journal
    PDF, 230 Кб, Файл опубликован: 7 июл 2015
  • Power Management > Switching Regulator > Inverting Regulators | SEPIC Regulators
  • Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
На английском языке: Datasheet Linear Technology LT8570-1
