Datasheet Linear Technology LT8610A — Даташит
СерияLT8610A
42V, 3.5A Synchronous Step-Down Regulator with 2.5µA Quiescent Current
Datasheet LT8610A, LT8610AB
PDF, 382 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 26
42V, 3.5A Synchronous Step-Down Regulator with 2.5μA Quiescent Current
LT8610A: 3.8-42Vin [email protected]
LT8610AEMSE#PBFLT8610AEMSE#TRPBFLT8610AEMSE-3.3#PBFLT8610AEMSE-3.3#TRPBFLT8610AEMSE-5#PBFLT8610AEMSE-5#TRPBFLT8610AHMSE#PBFLT8610AHMSE#TRPBFLT8610AHMSE-3.3#PBFLT8610AHMSE-3.3#TRPBFLT8610AHMSE-5#PBFLT8610AHMSE-5#TRPBFLT8610AIMSE#PBFLT8610AIMSE#TRPBFLT8610AIMSE-3.3#PBFLT8610AIMSE-3.3#TRPBFLT8610AIMSE-5#PBFLT8610AIMSE-5#TRPBF
N123456789101112131415161718
КорпусMS-16E
Габаритный чертеж корпуса
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
MS-16E
Код корпусаMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSEMSE
Индекс корпуса05-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-166705-08-1667
Количество выводов161616161616161616161616161616161616
Parameters / ModelsLT8610AEMSE#PBFLT8610AEMSE#TRPBFLT8610AEMSE-3.3#PBFLT8610AEMSE-3.3#TRPBFLT8610AEMSE-5#PBFLT8610AEMSE-5#TRPBFLT8610AHMSE#PBFLT8610AHMSE#TRPBFLT8610AHMSE-3.3#PBFLT8610AHMSE-3.3#TRPBFLT8610AHMSE-5#PBFLT8610AHMSE-5#TRPBFLT8610AIMSE#PBFLT8610AIMSE#TRPBFLT8610AIMSE-3.3#PBFLT8610AIMSE-3.3#TRPBFLT8610AIMSE-5#PBFLT8610AIMSE-5#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139ADC2012A,DC2139A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodBurst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good
Тактовая частота, kHz220022002200220022002200220022002200220022002200220022002200220022002200
Frequency Adjust Range200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz
Frequency Sync Range200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz200kHz - 2.2MHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА111111111111111111
Isupply, мА0.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.00250.0025
Max Phases111111111111111111
Monolithicдададададададададададададададададада
Количество выходов111111111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A3.53.53.53.53.53.53.53.53.53.53.53.53.53.53.53.53.53.5
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
SubnameLT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610ALT8610A
Switch Current, A6.76.76.76.76.76.76.76.76.76.76.76.76.76.76.76.76.76.7
Synchronousдададададададададададададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В424242424242424242424242424242424242
Vin Min, В3.43.43.43.43.43.43.43.43.43.43.43.43.43.43.43.43.43.4
Vout Max, В39.739.739.739.739.739.739.739.739.739.739.739.739.739.739.739.739.739.7
Vout Maximum.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin.98Vin
Vout Min, В0.970.970.970.970.970.970.970.970.970.970.970.970.970.970.970.970.970.97
Vref Accuracy Over Temp, %1.231.231.231.231.231.231.231.231.231.231.231.231.231.231.231.231.231.23
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT8610AB
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LT8610A
Публикации по теме
