Datasheet Linear Technology LT8711IFE#PBF — Даташит
Серия | LT8711 |
Модель | LT8711IFE#PBF |
Micropower Synchronous Multitopology Controller with 42V Input Capability
LT8711 - Micropower Synchronous Multitopology Controller with 42V Input Capability
PDF, 1.4 Мб, Файл закачен: 20 сен 2017
Купить LT8711IFE#PBF на РадиоЛоцман.Цены — от 237 до 1 225 ₽ 16 предложений от 8 поставщиков Buck, Boost, Buck-Boost, SEPIC Regulator Positive Output Step-Up, Step-Down DC-DC Controller IC 20-TSSOP-EP | |||
LT8711IFE#PBF Analog Devices | 237 ₽ | ||
LT8711IFE#PBF Analog Devices | 240 ₽ | ||
LT8711IFE#PBF Analog Devices | по запросу | ||
LT8711IFE#TRPBF Analog Devices | по запросу |
Корпус | TSSOP-20 |
Код корпуса | FE |
Индекс корпуса | 05-08-1663 (CB) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2234A |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | Burst Mode, 100% Duty Cycle, Resistor Set Frequency, External Synchronization |
Тактовая частота | 750 kHz |
Frequency Adjust Range | 100kHz - 750kHz |
Frequency Sync Range | 100kHz - 750kHz |
Integrated Inductor | нет |
Ishutdown | 1 мкА |
Isupply | 0.015 мА |
Monolithic | нет |
Количество выходов | 1 |
Sense Resistor | Rsense |
Switch Current | 20 A |
Synchronous | да |
Topology | Buck, Boost, Sepic, Zeta, Buck-Boost |
Topology 1 | Buck, Boost, Sepic, Zeta, Buck-Boost |
Vin Max | 42 В |
Vin Min | 4.5 В |
Vout Max | 42 В |
Vout Min | 0.8 В |
Vref Accuracy Over Temp | 2 % |
Vswitch Max | 42 В |
Серия: LT8711 (8)
- Power Management > Switching Regulator > Buck-Boost Regulators > External Power Switch Buck-Boost
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers | Micropower Buck Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
- Power Management > Switching Regulator > SEPIC Regulators
LT8711IFEPBF, LT8711IFE PBF
