Datasheet Linear Technology LTC1627CS8#PBF — Даташит
Серия | LTC1627 |
Модель | LTC1627CS8#PBF |
Monolithic Synchronous Step-Down Switching Regulator
Datasheet LTC1627
PDF, 240 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 16
Купить LTC1627CS8#PBF на РадиоЛоцман.Цены — от 95 до 1 597 ₽ 41 предложений от 25 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 500mA 8-SOIC (0.154, 3.90mm Width) | |||
LTC1627CS8 Analog Devices | от 95 ₽ | ||
LTC1627CS8#PBF Analog Devices | 158 ₽ | ||
LTC1627CS8 TRPBF Linear Technology | по запросу | ||
LTC1627CS8#PBF Linear Technology | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC195A |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | Burst Mode, External Synchronization, 100% Duty Cycle |
Тактовая частота | 350 kHz |
Frequency Sync Range | Up to 525kHz |
Integrated Inductor | нет |
Ishutdown | 15 мкА |
Isupply | 0.2 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 70 °C |
Выходной ток | 0.64 A |
Polyphase | нет |
Switch Current | 0.8 A |
Synchronous | да |
Topology | Buck |
Vin Max | 8.5 В |
Vin Min | 2.65 В |
Vout Max | 8.5 В |
Vout Maximum | Vin |
Vout Min | 0.8 В |
Vref Accuracy Over Temp | 1.5 % |
- Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Design Notes
- A New, High Efficiency, Monolithic Synchronous Step-Down Regulator Works with Single or Dual Li-Ion Batteries &mdash DN201PDF, 77 Кб, Файл опубликован: 1 мар 1999Выписка из документа
Статьи
- LTC1627 Monolithic Synchronous Step-Down Regulator Maximizes Single or Dual Li-Ion Battery Life &mdash LT JournalPDF, 253 Кб, Файл опубликован: 1 авг 1998Выписка из документа
Серия: LTC1627 (4)
- LTC1627CS8#PBF LTC1627CS8#TRPBF LTC1627IS8#PBF LTC1627IS8#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LTC1627CS8PBF, LTC1627CS8 PBF
