Datasheet Linear Technology LTC1735-1 — Даташит
СерияLTC1735-1
High Efficiency Synchronous Step-Down Switching Regulator
Datasheet LTC1735-1
PDF, 356 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 28
UV, OV and Reverse Supply Protection Controller Low Operating Current: 125??A
LTC17351CGпо запросу
МосЧип
TradeElectronics
LTC1735-1по запросу
LTC17351Sпо запросу
LTC1735CGN-1#PBFLTC1735CGN-1#TRPBFLTC1735CS-1#PBFLTC1735CS-1#TRPBFLTC1735IGN-1#PBFLTC1735IGN-1#TRPBFLTC1735IS-1#PBFLTC1735IS-1#TRPBF
N12345678
КорпусSSOP-16
Габаритный чертеж корпуса
SSOP-16
SO-16
SO-16
SSOP-16
SSOP-16
SO-16
SO-16
Код корпусаGNGNSSGNGNSS
Индекс корпуса05-08-1641 (GN16)05-08-1641 (GN16)05-08-1610 (S16)05-08-1610 (S16)05-08-1641 (GN16)05-08-1641 (GN16)05-08-1610 (S16)05-08-1610 (S16)
Количество выводов1616161616161616
Parameters / ModelsLTC1735CGN-1#PBFLTC1735CGN-1#TRPBFLTC1735CS-1#PBFLTC1735CS-1#TRPBFLTC1735IGN-1#PBFLTC1735IGN-1#TRPBFLTC1735IS-1#PBFLTC1735IS-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC267ADC267ADC267ADC267ADC267ADC267ADC267ADC267A
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power GoodExternal Synchronization, Resistor Set Frequency, Power Good
Тактовая частота, kHz300300300300300300300300
Frequency Adjust RangeUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHz
Frequency Sync RangeUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHzUp to 500kHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА1515151515151515
Isupply, мА0.450.450.450.450.450.450.450.45
Max Phases11111111
Monolithicнетнетнетнетнетнетнетнет
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A2020202020202020
Polyphaseнетнетнетнетнетнетнетнет
Sense ResistorRsenseRsenseRsenseRsenseRsenseRsenseRsenseRsense
Switch Current, A2020202020202020
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В3636363636363636
Vin Min, В3.53.53.53.53.53.53.53.5
Vout Max, В77777777
Vout Maximum7V7V7V7V7V7V7V7V
Vout Min, В0.80.80.80.80.80.80.80.8
Vref Accuracy Over Temp, %11111111
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
Design Notes
  • Active Voltage Positioning Reduces Output Capacitors &mdash Design Solutions 10
    PDF, 130 Кб, Файл опубликован: 1 ноя 1999
  • A Low Cost Dynamic VID Power Supply for PentiumВ® III Processors &mdash Design Solutions 7
    PDF, 83 Кб, Файл опубликован: 1 апр 1999
  • 2-Phase DC/DC Controller Reduces Capacitanceand Increases Battery Life in Portable Applications &mdash Design Solutions 9
    PDF, 106 Кб, Файл опубликован: 1 июн 1999
Статьи
  • A Third Generation Dual, Opposing-Phase Switching Regulator Controller &mdash LT Journal
    PDF, 172 Кб, Файл опубликован: 1 июн 1999
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
На английском языке: Datasheet Linear Technology LTC1735-1
