Datasheet Linear Technology LTC3112 — Даташит
Серия | LTC3112 |
15V, 2.5A Synchronous Buck-Boost DC/DC Converter
LTC3112 - 15V, 2.5A Synchronous Buck-Boost DC/DC Converter
PDF, 648 Кб, Версия: D, Файл закачен: 20 сен 2017
Купить LTC3112 на РадиоЛоцман.Цены — от 324 до 2 115 ₽ 38 предложений от 22 поставщиков Conv DC-DC 2.7V to 15V Synchronous Non-Inverting/Inverting/Step Up/Step Down Single-Out 2.5V to 14V 2.5A 20Pin TSSOP EP Tube | |||
LTC3113IFE LTC3115EFE-1 LTC4217HFE LTC3417AEFE LTC3112EFE LTC3778EF LTC2952IF LTC2309CF LTC2309IF IC | 324 ₽ | ||
LTC3112EDHD#PBF Analog Devices | 351 ₽ | ||
LTC3112EDHD#TRPBF Analog Devices | от 614 ₽ | ||
LTC3112EDHD#TRPBF Analog Devices | от 1 791 ₽ |
Parameters / Models | LTC3112EDHD#PBF | LTC3112EDHD#TRPBF | LTC3112EFE#PBF | LTC3112EFE#TRPBF | LTC3112HDHD#PBF | LTC3112HDHD#TRPBF | LTC3112HFE#PBF | LTC3112HFE#TRPBF | LTC3112IDHD#PBF | LTC3112IDHD#TRPBF | LTC3112IFE#PBF | LTC3112IFE#TRPBF | LTC3112MPDHD#PBF | LTC3112MPDHD#TRPBF | LTC3112MPFE#PBF | LTC3112MPFE#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A | DC1598A |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect | External Synchronization, Burst Mode, Power Good, Output Disconnect |
Тактовая частота, kHz | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 |
Frequency Sync Range | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz | 300kHz - 1.5MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Isupply, мА | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Synchronous | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Topology | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost | Buck-Boost |
Vin Max, В | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
Vin Min, В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
Vout Max, В | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 |
Vout Maximum | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V | 14V |
Vout Min, В | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
Vswitch Max, В | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
LTC3112EDHD#PBF | LTC3112EDHD#TRPBF | LTC3112EFE#PBF | LTC3112EFE#TRPBF | LTC3112HDHD#PBF | LTC3112HDHD#TRPBF | LTC3112HFE#PBF | LTC3112HFE#TRPBF | LTC3112IDHD#PBF | LTC3112IDHD#TRPBF | LTC3112IFE#PBF | LTC3112IFE#TRPBF | LTC3112MPDHD#PBF | LTC3112MPDHD#TRPBF | LTC3112MPFE#PBF | LTC3112MPFE#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- 15V, 2.5A Monolithic Buck-Boost DC/DC Converter with 95% Efficiency and Low Noise Operation &mdash LT JournalPDF, 2.4 Мб, Файл опубликован: 20 июл 2012Выписка из документа
Серия: LTC3112 (16)
- Power Management > Switching Regulator > Buck-Boost Regulators > Internal Power Switch Buck-Boost
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
