Datasheet Linear Technology LTC3115-1 — Даташит
СерияLTC3115-1
40V, 2A Synchronous Buck-Boost DC/DC Converter
LTC3115-1 - 40V, 2A Synchronous Buck-Boost DC/DC Converter
PDF, 627 Кб, Версия: B, Файл закачен: 20 сен 2017
LTC3115-1: 3.6-40Vin 5Vout@1A
LTC3115EDHD-1#PBFLTC3115EDHD-1#TRPBFLTC3115EFE-1#PBFLTC3115EFE-1#TRPBFLTC3115HFE-1#PBFLTC3115HFE-1#TRPBFLTC3115IDHD-1#PBFLTC3115IDHD-1#TRPBFLTC3115IFE-1#PBFLTC3115IFE-1#TRPBFLTC3115MPFE-1#PBFLTC3115MPFE-1#TRPBF
N123456789101112
Корпус5x4 DFN-16
Габаритный чертеж корпуса
5x4 DFN-16
TSSOP-20
TSSOP-20
TSSOP-20
TSSOP-20
5x4 DFN-16
5x4 DFN-16
TSSOP-20
TSSOP-20
TSSOP-20
TSSOP-20
Код корпусаDHDDHDFEFEFEFEDHDDHDFEFEFEFE
Индекс корпуса05-08-170705-08-170705-08-1663 (CA)05-08-1663 (CA)05-08-1663 (CA)05-08-1663 (CA)05-08-170705-08-170705-08-1663 (CA)05-08-1663 (CA)05-08-1663 (CA)05-08-1663 (CA)
Количество выводов161620202020161620202020
Parameters / ModelsLTC3115EDHD-1#PBFLTC3115EDHD-1#TRPBFLTC3115EFE-1#PBFLTC3115EFE-1#TRPBFLTC3115HFE-1#PBFLTC3115HFE-1#TRPBFLTC3115IDHD-1#PBFLTC3115IDHD-1#TRPBFLTC3115IFE-1#PBFLTC3115IFE-1#TRPBFLTC3115MPFE-1#PBFLTC3115MPFE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687ADC1687A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst ModeResistor Set Frequency, External Synchronization, Burst Mode
Тактовая частота, kHz200020002000200020002000200020002000200020002000
Frequency Adjust Range100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz
Frequency Sync Range100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz100kHz - 2MHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА333333333333
Isupply, мА0.050.050.050.050.050.050.050.050.050.050.050.05
Max Phases111111111111
Monolithicдададададададададададада
Количество выходов111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A222222222222
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнет
Synchronousдададададададададададада
TopologyBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-BoostBuck-Boost
Vin Max, В404040404040404040404040
Vin Min, В2.72.72.72.72.72.72.72.72.72.72.72.7
Vout Max, В404040404040404040404040
Vout Maximum40V40V40V40V40V40V40V40V40V40V40V40V
Vout Min, В2.72.72.72.72.72.72.72.72.72.72.72.7
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
Статьи
  • 2.7V to 40V Monolithic Buck-Boost DC/DC Expands Input Capabilities, Regulates Seamlessly through Automotive Cold-Crank and Load-Dump Transients &mdash LT Journal
    PDF, 3.9 Мб, Файл опубликован: 17 янв 2013
  • Power Management > Switching Regulator > Buck-Boost Regulators > Internal Power Switch Buck-Boost
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3115-1
