Datasheet Linear Technology LTC3407A-2 — Даташит
СерияLTC3407A-2
Dual Synchronous 800mA, 2.25MHz Step-Down DC/DC Regulator
Datasheet LTC3407A-2
PDF, 281 Кб, Язык: анг., Файл закачен: 21 сен 2017, Страниц: 16
Dual Synchronous 800mA,2.25MHz Step-Down DC/DC Regulator
LTC3407A-2по запросу
LTC3407AEDD-2#PBFLTC3407AEDD-2#TRPBFLTC3407AEMSE-2#PBFLTC3407AEMSE-2#TRPBFLTC3407AIDD-2#PBFLTC3407AIDD-2#TRPBFLTC3407AIMSE-2#PBFLTC3407AIMSE-2#TRPBF
N12345678
Корпус3x3 DFN-10
Габаритный чертеж корпуса
3x3 DFN-10
MS-10E
MS-10E
3x3 DFN-10
3x3 DFN-10
MS-10E
MS-10E
Код корпусаDDDDMSEMSEDDDDMSEMSE
Индекс корпуса05-08-169905-08-169905-08-166405-08-166405-08-169905-08-169905-08-166405-08-1664
Количество выводов1010101010101010
Parameters / ModelsLTC3407AEDD-2#PBFLTC3407AEDD-2#TRPBFLTC3407AEMSE-2#PBFLTC3407AEMSE-2#TRPBFLTC3407AIDD-2#PBFLTC3407AIDD-2#TRPBFLTC3407AIMSE-2#PBFLTC3407AIMSE-2#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Design ToolsLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty CycleBurst Mode, External Synchronization, Power On Reset, 100% Duty Cycle
Тактовая частота, kHz22502250225022502250225022502250
Frequency Sync Range1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz1.8MHz - 2.7MHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА0.10.10.10.10.10.10.10.1
Isupply, мА0.040.040.040.040.040.040.040.04
Max Phases11111111
Monolithicдададададададада
Количество выходов22222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A0.80.80.80.80.80.80.80.8
Output Current 2, A0.80.80.80.80.80.80.80.8
Polyphaseнетнетнетнетнетнетнетнет
Switch Current, A1.21.21.21.21.21.21.21.2
Switch Current 2, A1.21.21.21.21.21.21.21.2
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В5.55.55.55.55.55.55.55.5
Vin Min, В2.52.52.52.52.52.52.52.5
Vout Max, В5.55.55.55.55.55.55.55.5
Vout MaximumVinVinVinVinVinVinVinVin
Vout Min, В0.60.60.60.60.60.60.60.6
Vout Min 2, В0.60.60.60.60.60.60.60.6
Vref Accuracy Over Temp, %22222222
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Micropower Buck Regulators | Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LTC3407A-2
