Datasheet Linear Technology LTC3612 — Даташит
Серия | LTC3612 |
3A, 4MHz Monolithic Synchronous Step-Down DC/DC Converter
Datasheet LTC3612
PDF, 416 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 30
Купить LTC3612 на РадиоЛоцман.Цены — от 155 до 1 501 ₽ 38 предложений от 22 поставщиков IC: PMIC; преобразователь DC/DC; Uвх: 2,25÷5,5ВDC; 6А; QFN20; Ch: 1 | |||
LTC3612MPUDC#PBF Analog Devices | от 155 ₽ | ||
LTC3612EUDC#TRPBF Analog Devices | 253 ₽ | ||
LTC3612EFE Linear Technology | от 386 ₽ | ||
LTC3612FE | по запросу |
Parameters / Models | LTC3612EFE#PBF | LTC3612EFE#TRPBF | LTC3612EUDC#PBF | LTC3612EUDC#TRPBF | LTC3612HFE#PBF | LTC3612HFE#TRPBF | LTC3612HUDC#PBF | LTC3612HUDC#TRPBF | LTC3612IFE#PBF | LTC3612IFE#TRPBF | LTC3612IUDC#PBF | LTC3612IUDC#TRPBF | LTC3612MPFE#PBF | LTC3612MPFE#TRPBF | LTC3612MPUDC#PBF | LTC3612MPUDC#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A | DC1310A,DC1574A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle | Burst Mode, DDR Mode, Active Voltage Positioning, 100% Duty Cycle |
Тактовая частота, kHz | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 |
Frequency Adjust Range | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz |
Frequency Sync Range | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz | Up to 4MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Isupply, мА | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Synchronous | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vin Min, В | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 | 2.25 |
Vout Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vout Maximum | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin |
Vout Min, В | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
Vref Accuracy Over Temp, % | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
LTC3612EFE#PBF | LTC3612EFE#TRPBF | LTC3612EUDC#PBF | LTC3612EUDC#TRPBF | LTC3612HFE#PBF | LTC3612HFE#TRPBF | LTC3612HUDC#PBF | LTC3612HUDC#TRPBF | LTC3612IFE#PBF | LTC3612IFE#TRPBF | LTC3612IUDC#PBF | LTC3612IUDC#TRPBF | LTC3612MPFE#PBF | LTC3612MPFE#TRPBF | LTC3612MPUDC#PBF | LTC3612MPUDC#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- Monolithic Synchronous Step-Down Regulator Sources 3A or Sinks 1.5A in TSSOP or 3mm × 4mm QFN &mdash LT JournalPDF, 578 Кб, Файл опубликован: 1 дек 2009Выписка из документа
Серия: LTC3612 (16)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck
- Power Management > Switching Regulator > DDR Memory/Bus Termination
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
