Datasheet Linear Technology LTC3633AIFE-3#PBF — Даташит
Серия | LTC3633A-3 |
Модель | LTC3633AIFE-3#PBF |
Dual Channel 3A, 20V Monolithic Synchronous Step-Down Regulator
Datasheet LTC3633A-2, LTC3633A-3
PDF, 424 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 28
Купить LTC3633AIFE-3#PBF на РадиоЛоцман.Цены — от 426 до 1 977 ₽ 23 предложений от 13 поставщиков Buck Switching Regulator IC Positive Adjustable 1.5V 2 Output 3A 28-TSSOP (0.173, 4.40mm Width) Exposed Pad | |||
LTC3633AIFE-3#PBF Analog Devices | 426 ₽ | ||
LTC3633AIFE-3#TRPBF Linear Technology | 537 ₽ | ||
LTC3633AIFE-3#PBF Analog Devices | от 1 977 ₽ | ||
LTC3633AIFE-3#TRPBF Linear Technology | по запросу |
Корпус | TSSOP-28 |
Код корпуса | FE |
Индекс корпуса | 05-08-1663 (EB) |
Архитектура | Constant Frequency Controlled On-Time Current Mode |
Demo Boards | DC1896A |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Anti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good |
Тактовая частота | 4000 kHz |
Frequency Adjust Range | 500kHz - 4MHz |
Frequency Sync Range | 500kHz - 4MHz |
Integrated Inductor | нет |
Ishutdown | 13 мкА |
Isupply | 0.5 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 3 A |
Output Current 2 | 3 A |
Polyphase | нет |
Switch Current | 3.5 A |
Switch Current 2 | 3.5 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 20 В |
Vin Min | 3.6 В |
Vout Max | 12 В |
Vout Maximum | 12V |
Vout Min | 1.5 В |
Vout Min 2 | 1.5 В |
Vref Accuracy Over Temp | 1 % |
Серия: LTC3633A-3 (8)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Internal Power Switch Buck
LTC3633AIFE-3PBF, LTC3633AIFE-3 PBF, LTC3633AIFE3#PBF, LTC3633AIFE 3#PBF
