Datasheet Linear Technology LTC3633AIUFD-3#TRPBF — Даташит
Серия | LTC3633A-3 |
Модель | LTC3633AIUFD-3#TRPBF |
Dual Channel 3A, 20V Monolithic Synchronous Step-Down Regulator
Datasheet LTC3633A-2, LTC3633A-3
PDF, 424 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 28
Купить LTC3633AIUFD-3#TRPBF на РадиоЛоцман.Цены — от 418 до 3 178 ₽ 15 предложений от 9 поставщиков Buck Switching Regulator IC Positive Adjustable 1.5V 2 Output 3A 28-WFQFN Exposed Pad | |||
LTC3633AIUFD-3#TRPBF Analog Devices | 418 ₽ | ||
LTC3633AIUFD-3#TRPBF Linear Technology | 497 ₽ | ||
LTC3633AIUFD-3#TRPBF Analog Devices | от 3 178 ₽ | ||
LTC3633AIUFD-3#TRPBF Linear Technology | по запросу |
Корпус | 4x5 QFN-28 |
Код корпуса | UFD |
Индекс корпуса | 05-08-1712 |
Архитектура | Constant Frequency Controlled On-Time Current Mode |
Demo Boards | DC1896A |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Anti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good |
Тактовая частота | 4000 kHz |
Frequency Adjust Range | 500kHz - 4MHz |
Frequency Sync Range | 500kHz - 4MHz |
Integrated Inductor | нет |
Ishutdown | 13 мкА |
Isupply | 0.5 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 3 A |
Output Current 2 | 3 A |
Polyphase | нет |
Switch Current | 3.5 A |
Switch Current 2 | 3.5 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 20 В |
Vin Min | 3.6 В |
Vout Max | 12 В |
Vout Maximum | 12V |
Vout Min | 1.5 В |
Vout Min 2 | 1.5 В |
Vref Accuracy Over Temp | 1 % |
Серия: LTC3633A-3 (8)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Internal Power Switch Buck
LTC3633AIUFD-3TRPBF, LTC3633AIUFD-3 TRPBF, LTC3633AIUFD3#TRPBF, LTC3633AIUFD 3#TRPBF
