Datasheet Linear Technology LTC3633A-2 — Даташит
СерияLTC3633A-2
Dual Channel 3A, 20V Monolithic Synchronous Step-Down Regulator
Datasheet LTC3633A-2, LTC3633A-3
PDF, 424 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 28
LTC3633A-2: 3.6-20Vin 1.8/3.3Vout@3A
LTC3633AEFE-2#PBFLTC3633AEFE-2#TRPBFLTC3633AEUFD-2#PBFLTC3633AEUFD-2#TRPBFLTC3633AIFE-2#PBFLTC3633AIFE-2#TRPBFLTC3633AIUFD-2#PBFLTC3633AIUFD-2#TRPBF
N12345678
КорпусTSSOP-28
Габаритный чертеж корпуса
TSSOP-28
4x5 QFN-28
4x5 QFN-28
TSSOP-28
TSSOP-28
4x5 QFN-28
4x5 QFN-28
Код корпусаFEFEUFDUFDFEFEUFDUFD
Индекс корпуса05-08-1663 (EB)05-08-1663 (EB)05-08-171205-08-171205-08-1663 (EB)05-08-1663 (EB)05-08-171205-08-1712
Количество выводов2828282828282828
Parameters / ModelsLTC3633AEFE-2#PBFLTC3633AEFE-2#TRPBFLTC3633AEUFD-2#PBFLTC3633AEUFD-2#TRPBFLTC3633AIFE-2#PBFLTC3633AIFE-2#TRPBFLTC3633AIUFD-2#PBFLTC3633AIUFD-2#TRPBF
АрхитектураConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current Mode
Demo BoardsDC1896ADC1896ADC1896ADC1896ADC1896ADC1896ADC1896ADC1896A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodAnti-Phase Switching, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good
Тактовая частота, kHz40004000400040004000400040004000
Frequency Adjust Range500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz
Frequency Sync Range500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz500kHz - 4MHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА1313131313131313
Isupply, мА0.50.50.50.50.50.50.50.5
Max Phases22222222
Monolithicдададададададада
Количество выходов22222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A33333333
Output Current 2, A33333333
Polyphaseнетнетнетнетнетнетнетнет
Switch Current, A3.53.53.53.53.53.53.53.5
Switch Current 2, A3.53.53.53.53.53.53.53.5
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В2020202020202020
Vin Min, В3.63.63.63.63.63.63.63.6
Vout Max, В1212121212121212
Vout Maximum12V12V12V12V12V12V12V12V
Vout Min, В1.51.51.51.51.51.51.51.5
Vout Min 2, В1.51.51.51.51.51.51.51.5
Vref Accuracy Over Temp, %11111111
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LTC3633A-3 LTC3633A-3
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LTC3633A-2
