Datasheet Linear Technology LTC3634 — Даташит
Серия | LTC3634 |
15V Dual 3A Monolithic Step-Down Regulator for DDR Power
LTC3634 - 15V Dual 3A Monolithic Step-Down Regulator for DDR Power
PDF, 461 Кб, Версия: C, Файл закачен: 22 сен 2017
Купить LTC3634 на РадиоЛоцман.Цены — от 348 до 2 045 ₽ 36 предложений от 22 поставщиков LINEAR TECHNOLOGY LTC3634EFE#PBF DC-DC Switching Regulator, Synchronous, Dual, 1.4V to 15V in, 3V/3A out, 4.6MHz, TSSOP-28 | |||
LTC3634EUFD#PBF Analog Devices | 348 ₽ | ||
LTC3634EUFD#PBF Analog Devices | 353 ₽ | ||
LTC3634EUFD#PBF Analog Devices | 373 ₽ | ||
LTC3634EUFD Linear Technology | 921 ₽ |
Parameters / Models | LTC3634EFE#PBF | LTC3634EFE#TRPBF | LTC3634EUFD#PBF | LTC3634EUFD#TRPBF | LTC3634HFE#PBF | LTC3634HFE#TRPBF | LTC3634HUFD#PBF | LTC3634HUFD#TRPBF | LTC3634IFE#PBF | LTC3634IFE#TRPBF | LTC3634IUFD#PBF | LTC3634IUFD#TRPBF | LTC3634MPFE#PBF | LTC3634MPFE#TRPBF | LTC3634MPUFD#PBF | LTC3634MPUFD#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A | DC1708A,DC1839A |
Design Tools | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model | LTspice Model,LTpowerCAD Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good | DDR Mode, Resistor Set Frequency, External Synchronization, Power Good |
Тактовая частота, kHz | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 | 4000 |
Frequency Adjust Range | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz |
Frequency Sync Range | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz | 500kHz - 4MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
Isupply, мА | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Output Current 2, A | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Output Current 3, A | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 | 0.010 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 |
Switch Current 2, A | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 |
Synchronous | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Topology 1 | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Topology 2 | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Topology 3 | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO | LDO |
Vin Max, В | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
Vin Min, В | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 |
Vout Max, В | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Vout Max 2, В | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Vout Max 3, В | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Vout Maximum | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V | 3V |
Vout Min, В | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
Vout Min 2, В | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 |
Vout Min 3, В | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 |
LTC3634EFE#PBF | LTC3634EFE#TRPBF | LTC3634EUFD#PBF | LTC3634EUFD#TRPBF | LTC3634HFE#PBF | LTC3634HFE#TRPBF | LTC3634HUFD#PBF | LTC3634HUFD#TRPBF | LTC3634IFE#PBF | LTC3634IFE#TRPBF | LTC3634IUFD#PBF | LTC3634IUFD#TRPBF | LTC3634MPFE#PBF | LTC3634MPFE#TRPBF | LTC3634MPUFD#PBF | LTC3634MPUFD#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC3634 (16)
- Power Management > Switching Regulator > DDR Memory/Bus Termination
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
