HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Linear Technology LTC3646-1 — Даташит
СерияLTC3646-1
40V, 1A Synchronous Step-Down Converter
Datasheet LTC3646, LTC3646-1
PDF, 596 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 28
LTC3646-1 : 6.3-40Vin 5Vout@1A
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
LTC3646EDE-1#PBFLTC3646EDE-1#TRPBFLTC3646EMSE-1#PBFLTC3646EMSE-1#TRPBFLTC3646HDE-1#PBFLTC3646HDE-1#TRPBFLTC3646HMSE-1#PBFLTC3646HMSE-1#TRPBFLTC3646IDE-1#PBFLTC3646IDE-1#TRPBFLTC3646IMSE-1#PBFLTC3646IMSE-1#TRPBF
N123456789101112
Корпус4x3 DFN-14
Габаритный чертеж корпуса
4x3 DFN-14
MS-16E
MS-16E
4x3 DFN-14
4x3 DFN-14
MS-16E
MS-16E
4x3 DFN-14
4x3 DFN-14
MS-16E
MS-16E
Код корпусаDEDEMSEMSEDEDEMSEMSEDEDEMSEMSE
Индекс корпуса05-08-170805-08-170805-08-166705-08-166705-08-170805-08-170805-08-166705-08-166705-08-170805-08-170805-08-166705-08-1667
Количество выводов141416161414161614141616
Parameters / ModelsLTC3646EDE-1#PBFLTC3646EDE-1#TRPBFLTC3646EMSE-1#PBFLTC3646EMSE-1#TRPBFLTC3646HDE-1#PBFLTC3646HDE-1#TRPBFLTC3646HMSE-1#PBFLTC3646HMSE-1#TRPBFLTC3646IDE-1#PBFLTC3646IDE-1#TRPBFLTC3646IMSE-1#PBFLTC3646IMSE-1#TRPBF
АрхитектураConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current ModeConstant Frequency Controlled On-Time Current Mode
Demo BoardsDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-BDC1731A-A,DC1731A-B,DC1820A-A,DC1820A-B
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power GoodResistor Set Frequency, External Synchronization, Burst Mode, Power Good
Тактовая частота, kHz300030003000300030003000300030003000300030003000
Frequency Adjust Range200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz
Frequency Sync Range200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz200kHz - 3MHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА888888888888
Isupply, мА0.1400.1400.1400.1400.1400.1400.1400.1400.1400.1400.1400.140
Max Phases111111111111
Monolithicдададададададададададада
Количество выходов111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A111111111111
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнет
Switch Current, A1.21.21.21.21.21.21.21.21.21.21.21.2
Synchronousдададададададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В404040404040404040404040
Vin Min, В444444444444
Vout Max, В151515151515151515151515
Vout Maximum15V15V15V15V15V15V15V15V15V15V15V15V
Vout Min, В0.60.60.60.60.60.60.60.60.60.60.60.6
Vref Accuracy Over Temp, %1.51.51.51.51.51.51.51.51.51.51.51.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LTC3646 LTC3646
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | High Input Voltage Buck
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3646-1
