Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Linear Technology LTC3729L-6 — Даташит
СерияLTC3729L-6
PolyPhase, Synchronous Step-Down Switching Regulator
Datasheet LTC3729L-6
PDF, 356 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 28
LTC3729L-6по запросу
LTC3729LEUH-6#PBFLTC3729LEUH-6#TRPBF
N12
Корпус5x5 QFN-32
Габаритный чертеж корпуса
5x5 QFN-32
Код корпусаUHUH
Индекс корпуса05-08-169305-08-1693
Количество выводов3232
Parameters / ModelsLTC3729LEUH-6#PBFLTC3729LEUH-6#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current Mode
Design ToolsLTspice ModelLTspice Model
Экспортный контрольнетнет
Основные особенностиPolyPhasePolyPhase
Тактовая частота, kHz550550
Integrated Inductorнетнет
Ishutdown, мкА2020
Isupply, мА0.470.47
Max Phases2, 3, 4, 6, 8, 122, 3, 4, 6, 8, 12
Monolithicнетнет
Количество выходов11
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85
Выходной ток, A4040
Polyphaseдада
Sense ResistorRsenseRsense
Switch Current, A4040
Synchronousдада
TopologyBuckBuck
Vin Max, В3030
Vin Min, В44
Vout Max, В55
Vout Maximum5V5V
Vout Min, В0.60.6
Vref Accuracy Over Temp, %11
RoHSСовместимСовместим
  • PCB Layout Considerations for Non-Isolated Switching Power Supplies &mdash AN136
    PDF, 215 Кб, Файл опубликован: 20 сен 2012
    The best news when you power up a prototype supply board for the very first time is when it not only works, but also runs quiet and cool. Unfortunately, this does not always happen. A common problem of switching power supplies is “unstable” switching waveforms. Sometimes, waveform jittering is so pronounced that audible noise can be heard from the magnetic components. If the problem is related to the printed circuit board (PCB) layout, identifying the cause can be difficult. This is why proper PCB layout at the early stage of a switching supply design is very critical. Its importance cannot be overstated.
Серия: LTC3729L-6 (2)
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
На английском языке: Datasheet Linear Technology LTC3729L-6
