HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Linear Technology LTM4601A — Даташит
СерияLTM4601A
12A µModule (Power Module) Regulators with PLL, Output Tracking and Margining
Datasheet LTM4601A, LTM4601A-1
PDF, 532 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 30
12A μModule (Power Module) Regulators with PLL, Output Tracking and Margining
12A DC/DC ??Modules with PLL, Output Tracking and Margining
LTM4601A: 5-20Vin 2.5Vout@12A
LTM4601A-1
LTM4601AEV#PBFLTM4601AEY#PBFLTM4601AIV#PBFLTM4601AIYLTM4601AIY#PBF
N12345
Корпус15mm × 15mm × 2.82mm LGA
Габаритный чертеж корпуса
15mm x 15mm x 3.42mm BGA
Код корпусаLGABGALGABGABGA
Индекс корпуса05-08-175505-08-187705-08-175505-08-187705-08-1877
Количество выводов133133133133133
Parameters / ModelsLTM4601AEV#PBFLTM4601AEY#PBFLTM4601AIV#PBFLTM4601AIYLTM4601AIY#PBF
АрхитектураConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current Mode
Demo BoardsDC1414ADC1414ADC1414ADC1414ADC1414A
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнет
Основные особенностиTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power Good
Тактовая частота, kHz850850850850850
Frequency Sync Range600kHz - 1.1MHz600kHz - 1.1MHz600kHz - 1.1MHz600kHz - 1.1MHz600kHz - 1.1MHz
Integrated Inductorдадададада
Ishutdown, мкА2222222222
Isupply, мА3.83.83.83.83.8
Max Phases44444
Monolithicдадададада
Количество выходов11111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A1212121212
Polyphaseдадададада
Switch Current, A1717171717
Synchronousдадададада
TopologyBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuck
Vin Max, В2020202020
Vin Min, В4.54.54.54.54.5
Vout Max, В55555
Vout Maximum5V5V5V5V5V
Vout Min, В0.60.60.60.60.6
RoHSСовместимСовместимСовместимНе совместимСовместим
LTM4601A-1 LTM4601A-1
  • µModule Solutions > µModule Regulators > µModule Buck Regulators
На английском языке: Datasheet Linear Technology LTM4601A
Публикации по теме
