Datasheet Linear Technology LTM4601HV — Даташит
СерияLTM4601HV
12A 28VIN DC/DC µModule (Power Module) Regulator with PLL, Output Tracking and Margining
Datasheet LTM4601HV
PDF, 528 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 30
12A 28VIN DC/DC µModule Regulator with PLL, Output Tracking and Margining
12A 28VIN DC/DC ??Module with PLL, Output Tracking and Margining
LTM4601HV: 6-28Vin 3.3Vout@20A
LifeElectronics
LTM4601HV
LTM4601HVEV#PBFLTM4601HVEY#PBFLTM4601HVIV#PBFLTM4601HVIY#PBF
N1234
Корпус15mm × 15mm x 2.82mm LGA
Габаритный чертеж корпуса
15mm × 15mm × 3.42mm BGA
Код корпусаLGABGALGABGA
Индекс корпуса05-08-180105-08-190305-08-180105-08-1903
Количество выводов118118118118
Parameters / ModelsLTM4601HVEV#PBFLTM4601HVEY#PBFLTM4601HVIV#PBFLTM4601HVIY#PBF
АрхитектураConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current Mode
Demo BoardsDC1041A-BDC1041A-BDC1041A-BDC1041A-B
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнет
Основные особенностиTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power GoodTracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power Good
Тактовая частота, kHz850850850850
Frequency Sync Range600kHz - 1.1MHz600kHz - 1.1MHz600kHz - 1.1MHz600kHz - 1.1MHz
Integrated Inductorдададада
Ishutdown, мкА22222222
Isupply, мА3.83.83.83.8
Max Phases4444
Monolithicдададада
Количество выходов1111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85
Выходной ток, A12121212
Polyphaseдададада
Switch Current, A12121212
Synchronousдададада
TopologyBuckBuckBuckBuck
Topology 1BuckBuckBuckBuck
Vin Max, В28282828
Vin Min, В4.54.54.54.5
Vout Max, В5555
Vout Min, В0.60.60.60.6
RoHSСовместимСовместимСовместимСовместим
  • µModule Solutions > µModule Regulators > µModule Buck Regulators
На английском языке: Datasheet Linear Technology LTM4601HV
Публикации по теме
