HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Linear Technology LTM4608A — Даташит
СерияLTM4608A
Low VIN, 8A DC/DC µModule (Power Module) with Tracking, Margining, and Frequency Synchronization
Datasheet LTM4608A
PDF, 714 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 28
Low VIN, 8A DC/DC μModule Regulator with Tracking, Margining, and Frequency Synchronization
Low VIN, 8A DC/DC Module Regulator with Tracking, Margining, and Frequency Synchronization
LTM4608A_1по запросу
LTM4608AEV#PBFLTM4608AEY#PBFLTM4608AIV#PBFLTM4608AIY#PBFLTM4608AMPV#PBFLTM4608AMPYLTM4608AMPY#PBF
N1234567
Корпус15mm × 9mm × 2.82mm LGA
Габаритный чертеж корпуса
15mm x 9mm x 3.42mm BGA
Код корпусаLGALGALGALGALGABGABGA
Индекс корпуса05-08-182105-08-182105-08-182105-08-182105-08-182105-08-199305-08-1993
Количество выводов68686868686868
Parameters / ModelsLTM4608AEV#PBFLTM4608AEY#PBFLTM4608AIV#PBFLTM4608AIY#PBFLTM4608AMPV#PBFLTM4608AMPYLTM4608AMPY#PBF
АрхитектураConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current ModeConstant On-Time Current Mode
Demo BoardsDC1400ADC1400ADC1400ADC1400ADC1400ADC1400ADC1400A
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнет
Основные особенностиPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power GoodPolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power Good
Тактовая частота, kHz1500150015001500150015001500
Frequency Sync Range750kHz - 2.25MHz750kHz - 2.25MHz750kHz - 2.25MHz750kHz - 2.25MHz750kHz - 2.25MHz750kHz - 2.25MHz750kHz - 2.25MHz
Integrated Inductorдадададададада
Ishutdown, мкА1111111
Isupply, мА0.40.40.40.40.40.40.4
Max Phases4444444
Monolithicдадададададада
Количество выходов1111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125от -55 до 125
Выходной ток, A8888888
Polyphaseдадададададада
Switch Current, A13131313131313
Synchronousдадададададада
TopologyBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuck
Vin Max, В5.55.55.55.55.55.55.5
Vin Min, В2.72.72.72.72.72.72.7
Vout Max, В5555555
Vout Maximum5V5V5V5V5V5V5V
Vout Min, В0.60.60.60.60.60.60.6
RoHSСовместимСовместимСовместимСовместимСовместимНе совместимСовместим
  • µModule Solutions > µModule Regulators > µModule Buck Regulators | Extended Temperature (H & MP) µModule Regulators
На английском языке: Datasheet Linear Technology LTM4608A
Публикации по теме
