Datasheet Linear Technology LTC1261L — Даташит
СерияLTC1261L
Switched Capacitor Regulated Voltage Inverter
LTC1261L - Switched Capacitor Regulated Voltage Inverter
PDF, 2.6 Мб, Версия: A, Файл закачен: 27 сен 2017
LifeElectronics
LTC1261Lпо запросу
LTC1261LCMS8#PBFLTC1261LCMS8#TRPBFLTC1261LCMS8-4#PBFLTC1261LCMS8-4#TRPBFLTC1261LCMS8-4.5#PBFLTC1261LCMS8-4.5#TRPBFLTC1261LCS8#PBFLTC1261LCS8#TRPBFLTC1261LCS8-4#PBFLTC1261LCS8-4#TRPBFLTC1261LCS8-4.5#PBFLTC1261LCS8-4.5#TRPBFLTC1261LIMS8#PBFLTC1261LIMS8#TRPBFLTC1261LIMS8-4#PBFLTC1261LIMS8-4#TRPBFLTC1261LIMS8-4.5#PBFLTC1261LIMS8-4.5#TRPBFLTC1261LIS8#PBFLTC1261LIS8#TRPBFLTC1261LIS8-4#PBFLTC1261LIS8-4#TRPBFLTC1261LIS8-4.5#PBFLTC1261LIS8-4.5#TRPBF
N123456789101112131415161718192021222324
КорпусMS-8
Габаритный чертеж корпуса
MS-8
MS-8
MS-8
MS-8
MS-8
SO-8
SO-8
SO-8
SO-8
SO-8
SO-8
MS-8
MS-8
MS-8
MS-8
MS-8
MS-8
SO-8
SO-8
SO-8
SO-8
SO-8
SO-8
Код корпусаMS8MS8MS8MS8MS8MS8S8S8S8S8S8S8MS8MS8MS8MS8MS8MS8S8S8S8S8S8S8
Индекс корпуса05-08-166005-08-166005-08-166005-08-166005-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-166005-08-166005-08-166005-08-166005-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)
Количество выводов888888888888888888888888
Parameters / ModelsLTC1261LCMS8#PBFLTC1261LCMS8#TRPBFLTC1261LCMS8-4#PBFLTC1261LCMS8-4#TRPBFLTC1261LCMS8-4.5#PBFLTC1261LCMS8-4.5#TRPBFLTC1261LCS8#PBFLTC1261LCS8#TRPBFLTC1261LCS8-4#PBFLTC1261LCS8-4#TRPBFLTC1261LCS8-4.5#PBFLTC1261LCS8-4.5#TRPBFLTC1261LIMS8#PBFLTC1261LIMS8#TRPBFLTC1261LIMS8-4#PBFLTC1261LIMS8-4#TRPBFLTC1261LIMS8-4.5#PBFLTC1261LIMS8-4.5#TRPBFLTC1261LIS8#PBFLTC1261LIS8#TRPBFLTC1261LIS8-4#PBFLTC1261LIS8-4#TRPBFLTC1261LIS8-4.5#PBFLTC1261LIS8-4.5#TRPBF
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Тактовая частота, kHz650650650650650650650650650650650650650650650650650650650650650650650650
FunctionRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET BiasRegulated Inverting Charge Pump, GaAsFET Bias
Ishutdown, мкА555555555555555555555555
Isupply, мА0.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.650.65
Количество выходов111111111111111111111111
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A0.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.020.02
Выходное напряжение-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj-4V, -4.5V, Adj
Vin Max, В5.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.25
Vin Min, В2.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.72.7
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Inductorless (Charge Pump) DC/DC Converters > GaAsFET Bias Generators | Regulated Inverting Charge Pumps
На английском языке: Datasheet Linear Technology LTC1261L
