Datasheet Linear Technology LTC3255 — Даташит
Серия | LTC3255 |
Wide VIN Range Fault Protected 50mA Step-Down Charge Pump
LTC3255 - Wide VIN Range Fault Protected 50mA Step-Down Charge Pump
PDF, 259 Кб, Файл закачен: 27 сен 2017
Купить LTC3255 на РадиоЛоцман.Цены — от 201 до 1 042 ₽ 28 предложений от 16 поставщиков LINEAR TECHNOLOGY LTC3255HMSE#PBF DC-DC Adjustable Charge Pump Voltage Converter, 4V to 48V in, 2.4V to 12.5V/50mA out, MSOP-10 | |||
LTC3255EDD#PBF Analog Devices | 201 ₽ | ||
LTC3255EMSE#TRPBF Linear Technology | 250 ₽ | ||
LTC3255IDD Analog Devices | 593 ₽ | ||
LTC3255IDD#PBF IC Linear Technology | по запросу |
Parameters / Models | LTC3255EDD#PBF | LTC3255EDD#TRPBF | LTC3255EMSE#PBF | LTC3255EMSE#TRPBF | LTC3255HDD#PBF | LTC3255HDD#TRPBF | LTC3255HMSE#PBF | LTC3255HMSE#TRPBF | LTC3255IDD#PBF | LTC3255IDD#TRPBF | LTC3255IMSE#PBF | LTC3255IMSE#TRPBF | LTC3255MPDD#PBF | LTC3255MPDD#TRPBF | LTC3255MPMSE#PBF | LTC3255MPMSE#TRPBF |
Demo Boards | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A | DC2041A |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Тактовая частота, kHz | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 |
Function | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump | Regulated Step-Down Charge Pump |
Ishutdown, мкА | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Isupply, мА | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 | 0.030 |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Выходное напряжение | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) | Adj (2.4V to 12.5V) |
Vin Max, В | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 |
Vin Min, В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
LTC3255EDD#PBF | LTC3255EDD#TRPBF | LTC3255EMSE#PBF | LTC3255EMSE#TRPBF | LTC3255HDD#PBF | LTC3255HDD#TRPBF | LTC3255HMSE#PBF | LTC3255HMSE#TRPBF | LTC3255IDD#PBF | LTC3255IDD#TRPBF | LTC3255IMSE#PBF | LTC3255IMSE#TRPBF | LTC3255MPDD#PBF | LTC3255MPDD#TRPBF | LTC3255MPMSE#PBF | LTC3255MPMSE#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC3255 (16)
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Regulated Step-Down Charge Pumps | High Voltage Charge Pumps
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
