Datasheet Microchip ATMEGA328P-MMHR — Даташит
Производитель | Microchip |
Серия | ATmega328P |
Модель | ATMEGA328P-MMHR |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 32KB ISP flash memory with read-while-write capabilities, 1024B EEPROM, 2KB SRAM, 23 general purpose I/O lines, 32 general purpose working registers, three flexible timer/counters with compare modes, internal and external interrupts, serial programmable USART, a byte-oriented 2-wire serial interface, SPI serial port, a 6-channel 10-bit A/D converter (8-channels in TQFP and QFN/MLF packages), programmable watchdog timer with internal oscillator, and five software selectable power saving modes
Datasheet ATmega328/P - Summary
PDF, 407 Кб, Файл опубликован: 10 дек 2016, Страниц: 24
8-bit AVR Microcontrollers
DataSheet ATmega328/P
PDF, 3.4 Мб, Файл закачен: 11 мар 2018, Страниц: 445
AVR Microcontroller with picoPower Technology
Купить ATMEGA328P-MMHR на РадиоЛоцман.Цены — от 138 до 600 ₽ 27 предложений от 15 поставщиков RISC Microcontroller, 8Bit, FLASH, AVR RISC CPU, 20MHz, CMOS, PQCC28, 4 X 4MM, 1MM HEIGHT, 0.45MM PITCH, GREEN, PLASTIC, VQFN-28 | |||
ATMEGA328P-MMHR Microchip | 138 ₽ | ||
ATMEGA328P-MMHR Microchip | 194 ₽ | ||
ATMEGA328P-MMHR Atmel | 304 ₽ | ||
ATMEGA328P-MMHR Atmel | по запросу |
Корпус | VQFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 1024 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | 4x4x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 32 |
Размер памяти программ | 32 KB |
SPI | 2 |
SRAM | 2048 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: ATmega328P (15)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA328PMMHR, ATMEGA328P MMHR
