Datasheet Microchip ATmega128A — Даташит
Производитель | Microchip |
Серия | ATmega128A |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 128KB flash memory with read-while-write capabilities, 4KB EEPROM, 4KB SRAM, 53 general purpose I/O lines, 32 general purpose working registers, real time counter, four flexible timer/counters with compare modes and PWM, two USARTs , a byte oriented Two-wire serial interface, an 8-channel/10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
ATmega128A - Complete Datasheet
PDF, 5.9 Мб, Файл опубликован: 10 дек 2016
Купить ATmega128A на РадиоЛоцман.Цены — от 34 до 1 512 ₽ 63 предложений от 33 поставщиков MCU 128Kb FLASH, 4Kb RAM, 4Kb EEPROM, ISP, ADC, = ATMEGA128A-U-TW ATMEGA128-16AU ATMEGA128L-8AI ATMEGA128-6AI ATMEGA128L-8AC ATMEGA128-16AUR ATMEGA128L-8AU ATMEGA128L-8AUR ATMEGA128-16AI ATMEGA128-16AC ATMEGA128-8AI... | |||
ATMEGA128A-AU Microchip | 34 ₽ | ||
ATMEGA128A-AU Atmel | 100 ₽ | ||
ATMEGA128A-MU Microchip | от 1 293 ₽ | ||
ATMEGA128A-AU Microchip | по запросу |
ATMEGA128A-AN | ATMEGA128A-ANR | ATMEGA128A-AU | ATMEGA128A-AU-HCM | ATMEGA128A-AUR | ATMEGA128A-MN | ATMEGA128A-MNR | ATMEGA128A-MU | ATMEGA128A-MUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
Корпус | TQFP | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN |
Parameters / Models | ATMEGA128A-AN | ATMEGA128A-ANR | ATMEGA128A-AU | ATMEGA128A-AU-HCM | ATMEGA128A-AUR | ATMEGA128A-MN | ATMEGA128A-MNR | ATMEGA128A-MU | ATMEGA128A-MUR |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 |
High Voltage Capable | No | No | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
Math Accelerator | No | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
Max PWM outputs, including complementary | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
Package Width | 14x14x1mm | 14x14x1mm | 14x14x1mm | 14x14x1mm | 14x14x1mm | 9x9x1mm | 9x9x1mm | 9x9x1mm | 9x9x1mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No |
Pin count | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
Размер памяти программ, KB | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
SPI | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
SRAM, Bytes | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 | 4096 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Zero Cross detect | No | No | No | No | No | No | No | No | No |
Серия: ATmega128A (9)
- Microcontrollers > 8-bit Microcontrollers
