Datasheet Microchip ATMEGA164PA-AU — Даташит
Производитель | Microchip |
Серия | ATmega164PA |
Модель | ATMEGA164PA-AU |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 16KB ISP flash memory with read-while-write capabilities, 512B EEPROM, 1KB SRAM, 32 general purpose I/O lines, 32 general purpose working registers, a real time counter, three flexible timer/counters with compare modes and PWM, two USARTs, a byte oriented 2-wire serial interface, an 8-channel 10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
ATmega164PA - Complete Datasheet
PDF, 5.8 Мб, Файл опубликован: 10 дек 2016
ATmega164PA - Summary Datasheet
PDF, 520 Кб, Файл опубликован: 10 дек 2016
Купить ATMEGA164PA-AU на РадиоЛоцман.Цены — от 87 до 4 184 ₽ 35 предложений от 19 поставщиков AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 44-TQFP (10x10) | |||
ATMEGA164PA-AU Atmel | 87 ₽ | ||
ATMEGA164PA-AU Microchip | 212 ₽ | ||
ATmega164PA-AU | от 520 ₽ | ||
ATMEGA164PA-AU Microchip | от 701 ₽ |
Корпус | TQFP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 512 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 44 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | 10x10x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 44 |
Размер памяти программ | 16 KB |
SPI | 3 |
SRAM | 1024 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
Серия: ATmega164PA (13)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA164PAAU, ATMEGA164PA AU
