Datasheet Microchip ATMEGA169PA-MUR — Даташит
Производитель | Microchip |
Серия | ATmega169PA |
Модель | ATMEGA169PA-MUR |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 16KB ISP flash memory with read-while-write capabilities, 512B EEPROM, 1KB SRAM, 54/69 general purpose I/O lines, 32 general purpose working registers, a JTAG interface for boundary-scan and on-chip debugging/programming, a complete on-chip LCD controller with internal contrast control, three flexible timer/counters with compare modes, internal and external interrupts,serial programmable USART, a universal serial interface (USI) with start condition detector, an 8-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, SPI serial port, and five software selectable power saving modes
8-bit Atmel Microcontroller with 16/32/64KB In-System Programmable Flash
Купить ATMEGA169PA-MUR на РадиоЛоцман.Цены — от 191 до 2 795 ₽ 25 предложений от 13 поставщиков IC: микроконтроллер AVR; EEPROM: 512Б; SRAM: 1kБ; Flash: 16kБ; Cmp: 1 | |||
ATMEGA169PA-MUR Microchip | 191 ₽ | ||
ATMEGA169PA-MUR Microchip | 233 ₽ | ||
ATMEGA169PA-MUR Atmel | 355 ₽ | ||
ATMEGA169PA-MUR Atmel | по запросу |
Корпус | VQFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 512 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 64 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 16 МГц |
Max PWM outputs | 4 including complementary |
Количество компараторов | 1 |
Package Width | 9x9x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 64 |
Размер памяти программ | 16 KB |
SPI | 2 |
SRAM | 1024 Bytes |
Segmented LCD | 100 |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
ATmega169A ATmega3290A ATmega3290PA ATmega329A ATmega329PA ATmega6490A ATmega6490P ATmega649A ATmega649P
- Microcontrollers > 8-bit Microcontrollers
ATMEGA169PAMUR, ATMEGA169PA MUR
