Datasheet Intersil ISL28117 — Даташит
Производитель | Intersil |
Серия | ISL28117 |
40V Precision Low Power Operational Amplifiers
ISL28117, ISL28217, ISL28417, ISL28417SEH Datasheet
PDF, 1.6 Мб, Версия: 2017-11-30
Купить ISL28117 на РадиоЛоцман.Цены — от 62 до 109 ₽ 18 предложений от 15 поставщиков OP-AMP, 250uV OFFSET-MAX, 1.5MHz BAND WIDTH, PDSO8, ROHS COMPLIANT, PLASTIC, MO-187AA, MSOP-8 | |||
ISL28117FUZ-T7 Intersil | 62 ₽ | ||
ISL28117FBZ-T13 Intersil | 67 ₽ | ||
ISL28117FBZ-T7 Renesas | 81 ₽ | ||
ISL28117FRTZ-T13 Renesas | по запросу |
Parameters / Models | ISL28117FBBZ | ISL28117FBBZ-T13 | ISL28117FBBZ-T7 | ISL28117FBZ | ISL28117FBZ-T13 | ISL28117FBZ-T7 | ISL28117FRTBZ | ISL28117FRTBZ-T13 | ISL28117FRTBZ-T7 | ISL28117FRTBZ-T7A | ISL28117FRTZ | ISL28117FRTZ-T13 | ISL28117FRTZ-T7 | ISL28117FRTZ-T7A | ISL28117FUBZ | ISL28117FUBZ-T13 | ISL28117FUBZ-T7 | ISL28117FUBZ-T7A | ISL28117FUZ | ISL28117FUZ-T13 |
AVOL | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB |
Полоса частот | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz | 1.5 MHz |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Коэффициент подавления синфазного сигнала | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB |
Description | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers | 40V Precision Low Power Operational Amplifiers |
Enable | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
IBIAS | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA | 1 nA |
IOUT | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA | 43 mA |
IS (per amp) | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA | 0.44 mA |
Noise VN | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz | 8 nV/√Hz |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
PSRR | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB | 145 dB |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Rail-to-Rail Output | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Скорость нарастания | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs | 0.5 V/μs |
Thermal Shutdown | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Topology | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA |
VOS (max) | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV | 0.11 mV |
VOUT | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V | 18.5 V |
VS (max) | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V |
VS (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
ISL28117FBBZ | ISL28117FBBZ-T13 | ISL28117FBBZ-T7 | ISL28117FBZ | ISL28117FBZ-T13 | ISL28117FBZ-T7 | ISL28117FRTBZ | ISL28117FRTBZ-T13 | ISL28117FRTBZ-T7 | ISL28117FRTBZ-T7A | ISL28117FRTZ | ISL28117FRTZ-T13 | ISL28117FRTZ-T7 | ISL28117FRTZ-T7A | ISL28117FUBZ | ISL28117FUBZ-T13 | ISL28117FUBZ-T7 | ISL28117FUBZ-T7A | ISL28117FUZ | ISL28117FUZ-T13 | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL28117 (20)
- ISL28117FBBZ ISL28117FBBZ-T13 ISL28117FBBZ-T7 ISL28117FBZ ISL28117FBZ-T13 ISL28117FBZ-T7 ISL28117FRTBZ ISL28117FRTBZ-T13 ISL28117FRTBZ-T7 ISL28117FRTBZ-T7A ISL28117FRTZ ISL28117FRTZ-T13 ISL28117FRTZ-T7 ISL28117FRTZ-T7A ISL28117FUBZ ISL28117FUBZ-T13 ISL28117FUBZ-T7 ISL28117FUBZ-T7A ISL28117FUZ ISL28117FUZ-T13
- Amplifiers & Buffers > All Amplifiers > Amplifiers
