Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Linear Technology LTM4620A — Даташит
СерияLTM4620A
Dual 13A or Single 26A DC/DC µModule (Power Module) Regulator
Datasheet LTM4620A
PDF, 725 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 40
Dual 13A or Single 26A DC/DC µModule Regulator
LTM4620A: 5.5-16Vin 3.3/5Vout@13A
LTM4620AEV#PBFLTM4620AEY#PBFLTM4620AIV#PBFLTM4620AIYLTM4620AIY#PBFLTM4620AMPYLTM4620AMPY#PBF
N1234567
Корпус15mm × 15mm × 4.41mm LGA
Габаритный чертеж корпуса
15mm x 15mm x 5.01mm BGA
Код корпусаLGABGALGABGABGABGABGA
Индекс корпуса05-08-184405-08-188005-08-184405-08-188005-08-188005-08-188005-08-1880
Количество выводов144144144144144144144
Parameters / ModelsLTM4620AEV#PBFLTM4620AEY#PBFLTM4620AIV#PBFLTM4620AIYLTM4620AIY#PBFLTM4620AMPYLTM4620AMPY#PBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204BDC1759A,DC2268A-B,DC2204B
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнет
Основные особенностиInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power GoodInternal Heat Sink, Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power Good
Тактовая частота, kHz500500500500500500500
Frequency Adjust Range250kHz - 780kHz250kHz - 780kHz250kHz - 780kHz250kHz - 780kHz250kHz - 780kHz250kHz - 780kHz250kHz - 780kHz
Frequency Sync Range400kHz - 780kHz400kHz - 780kHz400kHz - 780kHz400kHz - 780kHz400kHz - 780kHz400kHz - 780kHz400kHz - 780kHz
Integrated Inductorдадададададада
Ishutdown, мкА50505050505050
Isupply, мА5555555
Max Phases8888888
Monolithicдадададададада
Количество выходов2222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A13131313131313
Polyphaseдадададададада
Switch Current, A20202020202020
Synchronousдадададададада
TopologyBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuckBuck
Vin Max, В16161616161616
Vin Min, В4.54.54.54.54.54.54.5
Vout Max, В5.35.35.35.35.35.35.3
Vout Maximum5.3V5.3V5.3V5.3V5.3V5.3V5.3V
Vout Min, В0.60.60.60.60.60.60.6
RoHSСовместимСовместимСовместимНе совместимСовместимНе совместимСовместим
Статьи
  • Real Power Density: 26A µModule Regulator Keeps Cool in Tight Spaces &mdash LT Journal
    PDF, 6.8 Мб, Файл опубликован: 18 окт 2012
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
  • µModule Solutions > µModule Regulators > µModule Buck Regulators | Extended Temperature (H & MP) µModule Regulators
На английском языке: Datasheet Linear Technology LTM4620A
Публикации по теме
