Datasheet Linear Technology LTM4642 — Даташит
Серия | LTM4642 |
20VIN, Dual 4A or Single 8A DC/DC µModule Regulator
Datasheet LTM4642
PDF, 1.1 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 32
20VIN, Dual 4A or Single 8A DC/DC μModule Regulator
Купить LTM4642 на РадиоЛоцман.Цены — от 832 до 6 225 ₽ 20 предложений от 10 поставщиков DC DC CNVRTR 0.6-5.5V 0.6-5.5V | |||
LTM8049EY LTM8025IV LTM4622AIY LTM4632EV LTM4642EY LTM4642IY LTM4617EV LTM2881IV-3 LTM4620IY LTM4620AIY IC | 832 ₽ | ||
LTM4642IY Analog Devices | 1 354 ₽ | ||
LTM4642IY Analog Devices | 1 373 ₽ | ||
LTM4642IY Analog Devices | по запросу |
LTM4642EY#PBF | LTM4642IY | LTM4642IY#PBF | |
N | 1 | 2 | 3 |
Корпус | 11.25mm x 9mm x 4.92mm BGA Габаритный чертеж корпуса | 11.25mm x 9mm x 4.92mm BGA Габаритный чертеж корпуса | 11.25mm x 9mm x 4.92mm BGA Габаритный чертеж корпуса |
Код корпуса | BGA | BGA | BGA |
Индекс корпуса | 05-08-1961 | 05-08-1961 | 05-08-1961 |
Количество выводов | 56 | 56 | 56 |
Parameters / Models | LTM4642EY#PBF | LTM4642IY | LTM4642IY#PBF |
Архитектура | Constant On-Time, Valley Current Mode | Constant On-Time, Valley Current Mode | Constant On-Time, Valley Current Mode |
Demo Boards | DC2194A | DC2194A | DC2194A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет |
Основные особенности | Tracking, PolyPhase, PowerGood, External Synchronization, Resistor Set Frequency, Burst Mode | Tracking, PolyPhase, PowerGood, External Synchronization, Resistor Set Frequency, Burst Mode | Tracking, PolyPhase, PowerGood, External Synchronization, Resistor Set Frequency, Burst Mode |
Тактовая частота, kHz | 1400 | 1400 | 1400 |
Frequency Adjust Range | 600kHz to 1.4MHz | 600kHz to 1.4MHz | 600kHz to 1.4MHz |
Frequency Sync Range | 600kHz to 1.4MHz | 600kHz to 1.4MHz | 600kHz to 1.4MHz |
Integrated Inductor | да | да | да |
Ishutdown, мкА | 10 | 10 | 10 |
Isupply, мА | 22 | 22 | 22 |
Monolithic | да | да | да |
Количество выходов | 2 | 2 | 2 |
Рабочий диапазон температур, °C | от 0 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 4 | 4 | 4 |
Output Current 2, A | 4 | 4 | 4 |
Polyphase | да | да | да |
Switch Current, A | 7 | 7 | 7 |
Switch Current 2, A | 7 | 7 | 7 |
Synchronous | да | да | да |
Topology | Buck | Buck | Buck |
Topology 1 | Buck | Buck | Buck |
Topology 2 | Buck | Buck | Buck |
Vin Max, В | 20 | 20 | 20 |
Vin Min, В | 4.5 | 4.5 | 4.5 |
Vout Max, В | 5.5 | 5.5 | 5.5 |
Vout Max 2, В | 5.5 | 5.5 | 5.5 |
Vout Maximum | 5.5V | 5.5V | 5.5V |
Vout Min, В | 0.6 | 0.6 | 0.6 |
Vout Min 2, В | 0.6 | 0.6 | 0.6 |
Vref Accuracy Over Temp, % | 1.5 | 1.5 | 1.5 |
RoHS | Совместим | Не совместим | Совместим |
Серия: LTM4642 (3)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- µModule Solutions > µModule Regulators > µModule Buck Regulators
