HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Microchip MCP609T-I/SLVAO — Даташит
СерияMCP609
МодельMCP609T-I/SLVAO
The MCP609 quad operational amplifier (op amp) has a gain bandwidth product of 155 kHz with a low typical operating current of 18.7 and an offset voltage that is less than 250 µV.
Datasheet MCP606, MCP607, MCP608
PDF, 707 Кб, Язык: анг., Файл опубликован: 24 сен 2009, Страниц: 42
The MCP606 operational amplifier (op amp) has a gain bandwidth product of 155 kHz with a low typical operating current of 18.7 µA and an offset voltage that is less than 250 µV
5 предложений от 2 поставщиков
IC OPAMP GP 155KHZ RRO 14SOIC
Utmel
MCP609T-I/SLVAO
от 29 ₽
Acme Chip
MCP609T-I/SLVAO
The MCP609 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP609 operates with a single supply voltage that can be as low as 2.5V, while drawing less than 25 of quiescent current per amplifier. The MCP609 is available in standard 14-lead PDIP, SOIC and TSSOP packages. This amplifier is ideal for battery and loop-powered applications as well as industrial process control, low-power battery-operated devices, portable equipment, data acquisition equipment, test equipment and low-end audio applications. AEC-Q100 Grade 1 qualification is available for this device
КорпусSOIC
Количество каналов4
Aol118 дБ
Automotive RecommendedYes
CMRR Min75 дБ
DescriptionLinear Op Amps
EMI ProtectionNo
GBWP155 kHz
Ib1 pA
Input Voltage Noise Density38 nV/rt(Hz)
Iq Max25 µA
Iq Typical19 µA
Isc17 мА
Lead Count14
Operating Voltage Range2.5 - 6.0 В
PM62 deg
PSRR Min80 дБ
Package Width.150In(3.90mm)
Rail-To-RailOut
Скорость нарастания0.08 V/µS
Unity Gain StableYes
Vos Max250 µV
ΔVos/ΔTa1.8 µV/°C
MCP606 MCP607 MCP608
  • Amplifiers and Linear > Operational Amplifiers > Precision
MCP609TI/SLVAO, MCP609T I/SLVAO
На английском языке: Datasheet Microchip MCP609T-I/SLVAO
