Datasheet Microchip MCP616T-I/SN — Даташит
Производитель | Microchip |
Серия | MCP616 |
Модель | MCP616T-I/SN |
The MCP616 operational amplifier (op amp) has a gain bandwidth product of 190 kHz with a low typical operating current of 19 µA and an offset voltage that is less than 150 µV.
2.3V to 5.5V Micropower Bi-CMOS Op Amps
Купить MCP616T-I/SN на РадиоЛоцман.Цены — от 43 до 1 048 ₽ 34 предложений от 17 поставщиков MCP616 Series 5.5V 190kHz Rail-to-Rail Micropower Bi-CMOS Op Amp - SOIC-8 | |||
MCP616T-I/SN Microchip | 43 ₽ | ||
MCP616T-I/SN Microchip | 66 ₽ | ||
MCP616T-I/SN Microchip | 157 ₽ | ||
MCP616T-I/SN Microchip | от 379 ₽ |
The MCP616 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP616 operates with a single supply voltage that can be as low as 2.3V, while drawing less than 25 µA of quiescent current. The MCP616 is available in standard 8-lead PDIP, SOIC and MSOP packages. This amplifier is ideal for battery and loop-powered applications as well as industrial process control, low-power battery-operated devices, portable equipment, data acquisition equipment, test equipment and low-end audio applications.
Корпус | SOIC |
Количество каналов | 1 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 80 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 190 kHz |
Ib | 15000 pA |
Input Voltage Noise Density | 32 nV/rt(Hz) |
Iq Max | 25 µA |
Iq Typical | 19 µA |
Isc | 17 мА |
Lead Count | 8 |
Operating Voltage Range | 2.3 - 5.5 В |
PM | 57 deg |
PSRR Min | 86 дБ |
Package Width | .150In(3.90mm) |
Rail-To-Rail | Out |
Скорость нарастания | 0.08 V/µS |
Unity Gain Stable | Yes |
Vos Max | 150 µV |
ΔVos/ΔTa | 2 µV/°C |
- MCP616-I/MS MCP616-I/P MCP616-I/SN MCP616T-I/MS MCP616T-I/SN
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP616TI/SN, MCP616T I/SN
